Howen Hero-ME31-12
Howen Hero-ME31-12 is a professional 12-channel AHD HDD MDVR. The device features GPS / 4G LTE / Wi-Fi, 12 AHD 1080P/720p cameras support, NAND flash support, HDD (up to 2TB), 1 backup SD card (up to 256 GB), 3 x RS232, 1 x RS485, 1x CAN (optional), and more.
Parameters (85)
Settings (5)
Howen Hero-ME31-12
Flespi parses telemetry data from your Howen Hero-ME31-12 into a standardized JSON and lets you send commands to Howen Hero-ME31-12 via API.
    "device.type.id": "Howen Hero-ME31-12",
    "protocol.id": "howen"
How to send commands to Howen Hero-ME31-12?
accelerometer.module.status.enum
Protocol-specific Accelerometer module (G-sensor) status, 0-unknown, 1-normal, 2-abnormal, 3-not exist
brake.status
Brake status
can.middle.left.door.status
CAN middle left door is opened
can.middle.right.door.status
CAN middle right door is opened
disk.capacity
MB
Disk capacity
disk.id
Disk id
disk.size
MB
Disk size
disk.state
Disk state
engine.temperature
Engine temperature
event.end.timestamp
Timestamp of the event end
event.start.timestamp
Timestamp of the event start
File name to be processed
file.type
File Type Code
geofence.in.alarm
Geofence in alarm event
geofence.out.alarm
Geofence out alarm event
gsm.status.enum
Protocol-specific Mobile network (GSM, 3G, 4G, LTE, 5G, ...) module status, 0-unknown, 1-normal, 2-abnormal, 3-not exist
impact.acceleration
Impact accelerometer value
inside.vehicle.humidity
Humidity sensor inside vehicle value, i.e. relative air humidity level
inside.vehicle.temperature
Temperature inside vehicle
line.enter.alarm
Line enter alarm
line.exit.alarm
Line exit alarm
low.speed.event
Low speed detected
move.backward.status
Move backward status
move.forward.status
Move forward status
network.ip.address
IP address of the network
network.ip.gateway
IP address of the network gateway
network.ip.mask
IP subnet mask
outside.vehicle.humidity
Humidity sensor outside vehicle value, i.e. relative air humidity level
outside.vehicle.temperature
Temperature outside vehicle
overtime.parking.alarm
Over time Parking
position.fix.enum
recording.status
Recording status
tilt.acceleration
Tilt accelerometer value
today.vehicle.mileage
Total calculated mileage for today
video.channel
Video Channel
wifi.module.status.enum
wifi.signal.level
WiFi signal level, percentage
Mobile Network
dialup
Mobile Network Configuration
type: Type
user: User Name
bakApn: Backup APN
passwd: Password
switch: Switch
SmsService: Service number
servercode: Server Code
Device Info
info
version: Version
device_model: Device model
Restart Device
restart
Restart Device
Send Short Message
send_short_message
Send Short Message
message: Message
Central Server
Central Server setup
server0: Server 1
server1: Server 2
server2: Server 3
server3: Server 4
