Queclink GD530MG
Queclink GD530MG is an LTE compact waterproof standby asset GPS tracker. The device features global LTE Cat M1/NB2 with 2G fallback, 2400mAh battery (up to 3 years of standby time), IP67 compliant casing, BLE 5.1 support, motion detection, low power alarm, power saving mode, and more.
Parameters (369)
Settings (3)
Queclink GD530MG
Flespi parses telemetry data from your Queclink GD530MG into a standardized JSON and lets you send commands to Queclink GD530MG via API.
    "device.type.id": "Queclink GD530MG",
How to send commands to Queclink GD530MG?
Report GTTEM
Report GTTEM
Report GTTEM
Array with all detected BLE beacons data objects. Each object contain list of assosiated parameteres sent by appropriate beacon. Standard parameter names used: *id* - beacon identification string. Usually it is beacon's UUID or MAC-address *local_name* - Beacons's Local Name *rssi* - BLE signal level. Units = dBm *battery.voltage* - Beacon's battery voltage. Units = volts *battery.level* - Beacon's battery level. Units = percentage *temperature* - Beacon's temperature. Units = celsius
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
can.doors.boot.status
Diagnostic trouble code read from CAN
The engine torque
CAN hish beams are on
CAN brake pedal pressed
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTCRD
Report GTTEM
Report GTFTP
Report GTFTP
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTTEM
Report GTTEM
Speed level at which harsh behaviour is detected: 1 - low, 2 - medium, 3 - high
Timestamp when image was taken
jamming.state
messages.beffered.count
Network state
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
position.fix.type.enum
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTGPS
record
Record, indexed parameter
report.reason.enum
SIM card state
Tacho driver card presence
Tachograph overspeed signal
AT Command
at
password: Device password
{"cmd":"GTOUT","payload":"1,,,0,0,0,0,5,1,0,,1,1,,,","password":"gv300"}
Custom Command
{"payload":"AT+GTOUT,gv300,1,,,0,0,0,0,5,1,0,,1,1,,,,FFFF$"}
