air.pressure
Air pressure
beam.level.degrees.x
Inverse Sinus of Beam Level in Deg X-Direction
beam.level.degrees.y
Inverse Sinus of Beam Level in Deg Y-Direction
beam.level.degrees.z
Inverse Sinus of Beam Level in Deg Z-Direction
geofence.violation.alarm.status
GeoFence violation alarm status
gravity.rotation.alarm.status
Gravity rotation alarm status
lora.adrbit
LoRa: ADRBit (Adaptive Data Rate on or off) set by the device
lora.channel
LoRa: Radio Channel (LC) used by the device
lora.customerid
LoRa: Customer ID associated to the Device Manager account
lora.devlrrcnt
LoRa: Number of LRRs which received this packet
lora.fcntdn
LoRa: The last downlink counter to the device
lora.fcntup
lora.fport
LoRa: FPort used by the device for this packet
lora.lrcid
LoRa: ID of the LRC (Core) that processed the packet
lora.lrrid
LoRa: ID of the LRR (Gateway) that processed the packet
lora.lrrrssi
LoRa: RSSI (Received signal strength indication) measured by the best LRR
lora.lrrsnr
LoRa: SNR (Signal-Noise Ratio) measured by the best LRR
lora.modelcfg
LoRa: ASCII ThingPark Cloud data set by provisioning
lora.position.latitude
LoRa: Latitude of the best LRR
lora.position.longitude
LoRa: Longitude of the best LRR
lora.spfact
LoRa: SF (Spreading Factor) used by device
lora.subband
LoRa: SUB-BAND used by the device
magnetic.rotation.alarm.status
Magnetic rotation alarm status
motion.alarm.status
Motion alarm status
vibration.alarm.status
Vibration alarm status
