Parameters-filter protocol
Integration level: params
Post-processing channel to filter (remove) specific parameters from the message.
flespi parses the Parameters-filter protocol messages into a JSON object with the fields listed below in the Parameters tab.
This post-processing channel protocol is designed to filter (remove) specific parameters from the messages of any standard channel.
A channel with the parameters-filter protocol can apply to any standard channel to post-process its messages. That post-processing stage will remove message parameters listed in the parameters-filter channel configuration just before message registration in the original (standard) channel.
For example, such a configuration will unconditionally remove position information (latitude and longitude) from all messages:
