Xirgo-mqtt-deprecated protocol
Integration level: params + settings
Parse and decode Xirgo Global binary messages into JSON. Get the parsed data from Xirgo Global devices via MQTT. Forward normalized data from Xirgo Global trackers to cloud platforms (AWS, Azure, etc.).
flespi parses the Xirgo-mqtt-deprecated protocol messages into a JSON object with the fields listed below in the Parameters tab.
Important: this is a deprecated version of xirgo-mqtt protocol that will be removed on March 10, 2022 — please use the new version instead.
Xirgo Global devices working over "xirgo-mqtt-deprecated" protocol connect to the MQTT broker to send messages and receive commands. Below is a detailed manual on how to configure the physical Xirgo Global device and the flespi channel to make them interact properly.
Configuration on the device side
a) MQTT topic configuration. The MQTT topics defined on the device side determine where the corresponding data will be saved. You have to subscribe to a certain topic (see Configuration on the flespi side below) to receive the necessary information on your end.
b) MQTT session parameters. Basic parameters for telemetry data sending to broker and connection timeouts.
c) MQTT broker address. Destination address where the data will be sent (depends on the broker).
d) MQTT authorization parameters. You have to define Client ID, Username, and Password in order to successfully authorize with the broker.
Note: if using the flespi broker, populate the Username field with the valid flespi token and leave the Password field blank.
You can generate a valid flespi token with the required set of permissions in the Tokens section of the flespi panel:
mqtt pub sub acl token
Note: on the screenshot above we specified the minimal permissions necessary for correct device operation — permission to publish the data received by the device and permission to accept configuration commands sent to the device. You can extend these permissions at your discretion if necessary.
To start receiving data from the Xirgo MQTT device, first, we need a valid token with proper access permissions (inverse to the ones given to the device — see above):
mqtt sub pub flespi acl token
Flespi needs to be able to subscribe to the data updates from the device and needs to be able to send (publish) commands to the device to change its configuration.
Then we create a channel of "xirgo-mqtt-deprecated" type. The channel configuration should be as follows:
create flespi channel xirgo-mqtt
As you may have noticed, the topics in the flespi channel configuration and the Xirgo device configuration should be identical to ensure seamless operability.
Note: you only need a valid flespi token to configure the flespi MQTT broker (suggested by default); to stick to another broker, pick the "arbitrary broker" option from the MQTT broker drop-down and configure appropriately.
Then you can create a flespi device for each tracker sending the data to the "xirgo-mqtt-deprecated" channel to benefit from dedicated long-term storage, access to telemetry, analytics, and more.
armed.status
Armed/disarmed status
can.check.engine.status
CAN check engine warning is on
can.driver.door.status
CAN driver door is opened
CAN driver seatbelt indicator is on
Total engine motorhours read from CAN
can.passenger.door.status
CAN passenger door is opened
CAN passenger seatbelt indicator is on
CAN brake pedal pressed
event.function
Event function
GSM base station ID
Alarm status for GSM jamming
GSM location area code
GSM mobile country code
Strength of GSM signal
locked.status
Locked/unlocked status
sensor.boolean.value
User-defined sensor boolean value
sensor.float.value
User-defined sensor float value
sensor.string.value
User-defined sensor string value
sensor.uint32.value
sensor.uint8.value
tacho.slot.activity
Slot activity from tachograph
ttl: Command time to live in seconds
output: Output ID
payload: Hex data to be sent to the device
