Toolbox guide
Detailed logs, real-time & historical messages, intervals, and so much more in a handy and functional interface.
Overview
Toolbox is a comprehensive instrument giving a complete understanding of what has happened to the flespi platform in each specific moment. It offers all available records (logs and messages) about all functional elements in your flespi account.
The entities are grouped into the following logical sections:
Accessing Toolbox
You can access Toolbox in several ways whichever is more convenient:
(i) Find the Toolbox item inside the Telematics hub, Storage, or MQTT menu section to open the respective Toolbox view:
flespi panel open toolbox
or (ii) navigate to the Logs & Messages tab on the item's card (available for all item types):
toolbox tab for flespi item
or (iii) open Toolbox separately at https://toolbox.flespi.io/:
standalone flespi toolbox
Note that when opened as a standalone application, Toolbox offers convenient filtering within one element type (e.g. channels, devices, etc.). You can filter all item types by name or id, and additionally can filter devices by ident (IMEI).
flespi toolbox filter items
Access by token
If you want to give a 3rd party (e.g. a hardware manufacturer, co-worker, etc.) access to a certain device (or a list of devices), you can generate an ACL token for them with the following permissions:
toolbox acl token
Then you can give the link of the following format to the 3rd party:
https://flespi.io/toolbox/#/login/{Token-with-ACL-to-specific-devices}
Main screen
When you open Toolbox for a particular item it will show either logs and messages panes (for channels and devices) or only logs page (for platform, streams, modems, calcs, plugins).
flespi toolbox main screen
Right sliding pane
Clicking on the message or log entry will open its detailed view in the right-side pane. The pane also allows seeing the message as a JSON object and see the map with the location received in the respective message parameters (position.latitude and position.longitude):
flespi toolbox right sliding pane
You can detach the pane and move it to any position on the screen:
flespi toolbox detach right pane
Columns management
Add/remove columns
You can customize the set of displayed columns and their order.
To add a new column, right-click anywhere on the table header and pick Add column
flespi toolbox add column
Then start typing the column name and pick the needed column from the list:
flespi toolbox find column to add
To delete a column right-click on its header and pick Remove column:
flespi toolbox remove column
Drag the column by its header to change its position in the table.
Column presets
Use the three dots menu to the right of the date picker to revert to default columns or to columns defined by the protocol schema.
Once you configure the columns layout differently from the default setup, you will be able to save your own column preset.
flespi toolbox columns management
Logs pane
Logs pane is available for ALL item types. Logs include entries about all the events associated with the specific item. The colors of log records are intended to drag attention to more important events (usually related to the modification, deletion, errors, and warnings).
flespi toolbox logs pane
Searching logs
Use the search bar to narrow down the log records to a subset meeting specific criteria. Search by any parameter(s), use logical operations (=, <>, >, <=, etc.) and wildcards (*). Use the quotation marks for string values. When listing multiple criteria separated by a comma, AND logic applies.
flespi toolbox search logs
Note that the parameter name you need to specify in the search bar may not be the same as the parameter column header. You can find the proper name in the log record or message JSON.
Filtering logs
Filter logs by event type to get only the records you care about:
flespi toolbox filter logs by event type
Messages pane
Messages pane shows the messages received from the physical device or OEM platform parsed according to the protocol specification. The default set and order of the displayed column depends on the protocol schema and can be customized at any time.
flespi toolbox messages pane
Searching messages
Use the search bar to narrow down the messages to a subset meeting specific criteria. Search by any parameter(s), use logical operations (=, <>, >, <=, etc.) and wildcards (*). Use the quotation marks for string values. When listing multiple criteria separated by a comma, AND logic applies.
flespi toolbox messages search
Message colors
Toolbox color-codes device messages depending on their "freshness":
  • grey come from the past (flushing blackbox or wrong device settings); the darker grey means farther into the past
  • orange come from the future (wrong device settings); the darker orange means farther into the future
  • white come from the present (soon after the device records the data)
flespi toolbox messages colors
re-registered messages
Context menu
Right-clicking on a message opens the context menu with some helpful options:
flespi toolbox context menu
  • Copy option will copy the specific value in the cell on which the right-click was made
  • Copy message will copy the entire message with all parameters as the JSON object
  • Show message will open the right sliding pane with the full message object
  • View in traffic will open the Traffic Viewer tool and show the raw representation of the selected message
  • Show on map allows quickly seeing the dot on the map with the latitude/longitude taken from the selected line.
Intervals
Intervals are a different entity generated based on multiple messages. Intervals have a separate view available for devices with assigned calculators only:
flespi toolbox intervals
Once in the Intervals mode, you should pick the desired calculator assigned to the selected device to see the intervals for:
flespi toolbox interval mode
Map
A built-in map for quick dot-on-the-map visualization is available for devices only (since they correspond to the vehicles or assets being tracked).
You can click on the Map button at the top right of the screen to see the last position of the current device based on its position.latitude and position.longitude parameters stored in telemetry.
flespi toolbox open map
Tools
Toolbox has a few complementary tools that may be helpful for advanced debugging and troubleshooting.
Traffic Viewer
Traffic Viewer is a handy tool to analyze raw messages from any IoT and telematics devices (supported in flespi).
You can see the raw traffic data for any channel or device in your flespi account:
flespi toolbox traffic viewer
When opening Traffic Viewer for a channel, you will be prompted to pick the specific ident to show the traffic for.
flespi traffic viewer hex message
Read more about the tool here.
Error traffic viewer
This is a special breed of traffic viewer that highlights the traffic related to a specific parsing error. Right-click on the error message in the Logs pane and select View error traffic in the context menu:
view error traffic toolbox
The raw error traffic will be highlighted in red:
error traffic highlighted
HEX Viewer
This tool works for proxy channels only and allows investigating data packets in raw hexadecimal format with more convenience. Check the dedicated article here.
Despite being such a powerful and multi-functional tool, Toolbox will be getting occasional updates when our developers implement their new bright ideas. To stay in sync with the latest changes, subscribe to the Toolbox change log on our forum.
Options for viewing and exporting raw traffic data.
Resources you should monitor to stay in sync with all changes introduced to the flespi platform infrastructure.
