The channel will expect HTTP POST requests with payload data in GM OnStar protocol format.
To start receiving vehicle data from the GM OnStar telematics system perform the following steps:
1. Create a channel of ‘general-motors-onstar’ protocol. Contact your GM manager and provide them with a channel URI, so that they configure the Target URL where GM will be pushing vehicle data to.
Important note: In order for commands to General Motors OnStar devices to work properly, there must be only one ‘general-motors-onstar’ channel per flespi account.
2. Provide GM with the flespi outbound IP address 185.213.2.10, so that they whitelist it for inbound requests from the flespi platform to GM.
3. Once you have received the API credentials from GM, paste them into the Credentials section of the channel configuration on the Edit tab:
4. Create General Motors OnStar devices in flespi for each vehicle that you want to receive telemetry for and use vehicle VIN as ident:
5. Execute the “provision_device” command (Commands & Settings tab) for each device to Opt In the device in GM for the listed services:
As soon as the command is executed successfully, the GM platform will start sending the vehicle telemetry data to the channel. You can see the incoming messages on the Logs & Messages tab.
INTERM_VOLT_BATT_VOLT
AMBIENT_AIR_TEMPERATURE
can.exhaust.fuel.indicator.status
CAN exhaust fuel indicator status
EXHST_FL_LEVL_WARN_IND
Lifetime fuel used
Lifetime fuel economy
can.soot.filter.indicator.status.1
Soot filter indicator status #1
EXHST_PART_FLTR_WARN_ON
can.soot.filter.indicator.status.2
Soot filter indicator status #2
EXHST_PART_FLTR_WARN2_ON
CURRENT_SPEED
WASHER_FLUID_LOW
driver.seatbelt.indicator.status
Driver seatbelt indicator
DRIVER_SEATBELT_INDICATOR
dtc.action
DTC action
DTCSystem/DTCData/CorrectiveActionDescription
dtc.active.status
DTC active status
DTCSystem/DTCData/IsActive
dtc.code
DTC code
DTCSystem/DTCData/DTCCode
dtc.description
DTC description
DTCSystem/DTCData/DTCDescription
dtc.module.id
DTC module id
DTCSystem/DTCData/Module/ModuleID
dtc.open.timestamp
DTC open timestamp
DTCSystem/DTCData/DTCOpenDate
dtc.reset.timestamp
DTC reset timestamp
DTCSystem/DTCData/ResetDate
dtc.severity.code
DTC severity code
DTCSystem/DTCData/ServerityCode
dtc.status.byte
DTC status byte
DTCSystem/DTCData/StatusByte
dtc.subsystem.id
DTC subsystem id
DTCSystem/SubSystems/SubSystemID
dtc.subsystem.name
DTC subsystem name
DTCSystem/SubSystems/SubSystemName
dtc.system.name
DTC system name
DTCSystem/SystemName
engine.coolant.temperature
Engine coolant temperature
ENGINE_COOLANT_TEMP
engine.ignition.change.status
Engine ignition change status
IgnitionStateChange
engine.ignition.enabled
Engine ignition enabled
Engine ignition is enabled
IsIgnOff
ENGINE_RUN_TIME_TOTAL
ENGINE_RPM
fuel.capacity
Fuel Capacity
Fuel Capacity
Fuel level
Fuel amount
gas.range
Gas range
Gas range
CELL_SERVICE
oil.life
Oil life
Oil life
park.neutral.ckeck
Park neutral check
PARK_NEUTRAL_CHECK
passenger.seatbelt.indicator.status
Passenger seatbelt indicator
FRONT_PASSENGER_SEATBELT_INDICATOR
passenger.seat.occupied.status
Front passenger occupant status
FRONT_PASSENGER_OCCUPANT_STATUS
EHPE
ELV,
Elevation
Direction
Latitude
Longitude
Speed
AGEIND
power.mode
System power mode
SYSTEM_POWER_MODE
Maximum acceleration value that occured on the segment
SPEED_RATE_OF_CHANGE
Maximum braking acceleration value that occured on the segment
SPEED_RATE_OF_CHANGE_POSITIVE
tire.placard.front
Tire Pressure placard front
tire.placard.rear
Tire Pressure placard rear
tire.pressure.lf
Tire Pressure LF
Tire Pressure LF
tire.pressure.lr
Tire Pressure LR
Tire Pressure LR
tire.pressure.rf
Tire Pressure RF
Tire Pressure RF
tire.pressure.rr
Tire Pressure RR
Tire Pressure RR
tire.pressure.state.fr
Right front tire pressure status
RIGHT_FRONT_TIRE_PRESSURE_STATUS
tire.pressure.state.lf
Left front tire pressure status
LEFT_FRONT_TIRE_PRESSURE_STATUS
tire.pressure.state.lr
Left rear tire pressure status
LEFT_REAR_TIRE_PRESSURE_STATUS
tire.pressure.state.rr
Right rear tire pressure status
RIGHT_REAR_TIRE_PRESSURE_STATUS
total.engine.idle.time
Total engine idle time
LIFETIME_ENG_IDLE_TIME
Trip A total distance
ODO_READ
