Digital Matter Barra Edge
Digital Matter Barra Edge is a low-cost, LTE-M/NB-IoT network-enabled indoor/outdoor asset tracker with a 10+ year deploy-once battery life via 2 AA batteries. It features a slim, ultra-rugged IP68, IK07 housing, magnetic switch for activation and tamper detection, cloud-based location solving, and GNSS, Wi-Fi, and cell tower positioning. LTE bands for global coverage, eSIM ready, an internal antenna system, and adaptive tracking technology are included.
Parameters (80)
Flespi parses telemetry data from your Digital Matter Barra Edge into a standardized JSON and lets you send commands to Digital Matter Barra Edge via API.
    "device.type.id": "Digital Matter Barra Edge",
    "protocol.id": "digital-matter-edge"
accelerometer.wakeup.number
Device Counters
battery.capacity.used
Battery Capacity Used
Device Counters
Device Counters
Analogue values,
Device Counters
battery.voltage.initial
Device Counters
Position info
ble.failures.count
BLE failures counter
Device Counters
ble.scans.count
BLE scans counter
Device Counters
ble.uptime
BLE uptime counter
Device Counters
counter.rx.range
Device Counters
counter.tx.power
Device Counters
counter.uploads
Device Counters
counter.uploads.failed
Device Counters
counter.uploads.failed.time
Device Counters
counter.uploads.time
Device Counters
device.state.bitmask
Device state bitmask
Analogue values
device.temperature.max
Device Counters
Device Counters
Average Failed GPS Fix Time
Device Counters
gnss.average.fix.duration
Device Counters
gnss.average.refresh.time
Average GPS Freshen Time
Device Counters
gnss.position.fixes
Device Counters
gnss.position.fixes.failed
Device Counters
Device Counters
gnss.position.fixes.time
Device Counters
gnss.refresh.attempts
Device Counters
gnss.refresh.duration
Device Counters
Position info
Cell tower data
Cell tower data
Cell tower data
Cell tower data
Cell tower data
hardware.version.enum
Hardware version enum
jostle.position.fixes
Device Counters
jostle.position.fixes.uploads
Device Counters
loaded.battery.voltage
Loaded battery voltage
Analogue values
lora.application.id
LoRaWAN Application ID
Lora details
lora.device.address
LoRaWAN Device Address
Lora details
lora.device.id
LoRaWAN Device ID
Lora details
lora.gateway.id
LoRaWAN Gateway identifier
Lora details,
Lora gateway
lora.rssi
LoRaWAN Received Signal Strength Indication
Lora details,
Lora gateway
lora.snr
LoRaWAN Signal-to-Noise Ratio
Lora details,
Lora gateway
Analogue values
position.gdop
Geometric dilution of precision
Position info
Position info
Position info
position.source.enum
Number of position source
Position info
recovery.mode.status
Recovery Mode On/Off
Log reasons
Log reasons
trip.average.wakeup.number
Average Wakeups Per Trip
Device Counters
Device Counters
Log reasons
wifi.channel
WiFi channel number
Wi-Fi data
wifi.failed.scans
Count of failed Wi-Fi scans
Device Counters
Wi-Fi data
Wi-Fi data
wifi.successful.scans
Device Counters
