Digital Matter Dart2
Digital Matter Dart2 is a robust and affordable 4G vehicle GPS tracker. The device features 4G LTE-M / NB-IoT connectivity, high-precision GPS/GLONASS, 200mAh internal Li-Pol backup battery, 2 x digital inputs, 1 x switched ground digital output, 1 x ignition digital input, switched power out, configure iButton® and RFID readers for Driver ID, accident, speeding, harsh braking, and rollover detection, and more.
Parameters (100)
Settings (11)
Commands (3)
Flespi parses telemetry data from your Digital Matter Dart2 into a standardized JSON and lets you send commands to Digital Matter Dart2 via API.
    "device.type.id": "Digital Matter Dart2",
How to send commands to Digital Matter Dart2?
accelerometer.wakeup.number
battery.capacity.used
Battery Capacity Used
battery.capacity.used.initial
Battery Capacity Used Initial
battery.voltage.initial
ble.failures.count
BLE failures counter
ble.scans.count
BLE scans counter
ble.uptime
BLE uptime counter
counter.rx.range
counter.tx.power
counter.uploads
counter.uploads.failed
counter.uploads.failed.time
counter.uploads.time
device.run.time
Device run time
device.state.bitmask
Device state bitmask
device.temperature.max
error.level
Protocol-specific error level
error.type.description
Average Failed GPS Fix Time
gnss.average.fix.duration
gnss.average.refresh.time
Average GPS Freshen Time
gnss.position.fixes
gnss.position.fixes.failed
gnss.position.fixes.time
gnss.refresh.attempts
gnss.refresh.duration
gnss.sniffing.data.hex
gsm.arfcn
gsm.network.type.enum
gsm.pcid
gsm.timing.difference
ms
GSM timing difference
jostle.position.fixes
jostle.position.fixes.uploads
loaded.battery.voltage
Loaded battery voltage
network.signal.rspq
pin.4.digit
4 digit PIN
pin.5.digit
5 digit PIN
position.fix.type
Message type 0x04
Message type 0x04
Message type 0x04
Message type 0x04
trip.average.wakeup.number
Average Wakeups Per Trip
trip.movement.trim.duration
Movement trip trimming amount
vehicle.odometer
wifi.channel
WiFi channel number
wifi.failed.scans
Count of failed Wi-Fi scans
wifi.successful.scans
accident_data
partition: Partition control
config_oem
Delete all System Parameters
delete_all_system_parameters
Immobilise
immobilise
Change state of any immobiliser outputs.
value: immobiliser
Modem Reset
modem_reset
Set Odometer
value: Odometer value
Set Operational Mode
operational_mode
Remote Reset
remote_reset
Set Run Hours
run_hours
value: Run hours value
Send message
send_message
Send a message to the device
message: Message text
Set and enable SIM PIN
sim_pin
pin: SIM PIN
Custom async command
cmd_body: Async Message Body
cmd_type: Async Message Type
Delete a System Parameter
delete_system_parameter
param_id: Parameter ID
Set a System Parameter
set_system_parameter
