Vjoycar T80
Vjoycar T80 is a bike LED light with GPS tracking and 4G. The device features GPS/Beidou/AGPS/LBS, a 900 mAh rechargeable battery, waterproof IP67-compliant casing, LED rolling lights, SOS button, geofencing, low battery alarm, and more.
Parameters (45)
Vjoycar T80
Flespi parses telemetry data from your Vjoycar T80 into a standardized JSON and lets you send commands to Vjoycar T80 via API.
    "device.type.id": "Vjoycar T80",
    "protocol.id": "vjoycar"
How to send commands to Vjoycar T80?
bad.battry.alarm
Bad battery alarm
battery.input.voltage
Battery input voltage
device.installed.status
engine.blocked.alarm
Engine blocked alarm
ignition.alarm
Ignition alarm
open.alarm
Open alarm
wifi.channel
WiFi channel number
Custom Command
More devices from Vjoycar
No results found.
