Digital Matter Yabby Edge Cellular
Yabby Edge Cellular is an ultra-rugged and compact battery-powered asset tracker. It supports LTE-M/NB-IoT connectivity with cloud-based location service. The device features GNSS (GPS/BeiDou) and Wi-Fi AP MAC address scanning. Smart "sleep mode" and battery level alerts provide 10+ years of battery life. Meets IP68 and IK06 housing requirements.
Parameters (80)
Flespi parses telemetry data from your Digital Matter Yabby Edge Cellular into a standardized JSON and lets you send commands to Digital Matter Yabby Edge Cellular via API.
    "device.type.id": "Digital Matter Yabby Edge Cellular",
    "protocol.id": "digital-matter-edge"
accelerometer.wakeup.number
Device Counters
battery.capacity.used
Battery Capacity Used
Device Counters
Device Counters
Analogue values,
Device Counters
battery.voltage.initial
Device Counters
Position info
ble.failures.count
BLE failures counter
Device Counters
ble.scans.count
BLE scans counter
Device Counters
ble.uptime
BLE uptime counter
Device Counters
counter.rx.range
Device Counters
counter.tx.power
Device Counters
counter.uploads
Device Counters
counter.uploads.failed
Device Counters
counter.uploads.failed.time
Device Counters
counter.uploads.time
Device Counters
device.state.bitmask
Device state bitmask
Analogue values
device.temperature.max
Device Counters
Device Counters
Average Failed GPS Fix Time
Device Counters
gnss.average.fix.duration
Device Counters
gnss.average.refresh.time
Average GPS Freshen Time
Device Counters
gnss.position.fixes
Device Counters
gnss.position.fixes.failed
Device Counters
Device Counters
gnss.position.fixes.time
Device Counters
gnss.refresh.attempts
Device Counters
gnss.refresh.duration
Device Counters
Position info
Cell tower data
Cell tower data
Cell tower data
Cell tower data
Cell tower data
hardware.version.enum
Hardware version enum
jostle.position.fixes
Device Counters
jostle.position.fixes.uploads
Device Counters
loaded.battery.voltage
Loaded battery voltage
Analogue values
lora.application.id
LoRaWAN Application ID
Lora details
lora.device.address
LoRaWAN Device Address
Lora details
lora.device.id
LoRaWAN Device ID
Lora details
lora.gateway.id
LoRaWAN Gateway identifier
Lora details,
Lora gateway
lora.rssi
LoRaWAN Received Signal Strength Indication
Lora details,
Lora gateway
lora.snr
LoRaWAN Signal-to-Noise Ratio
Lora details,
Lora gateway
Analogue values
position.gdop
Geometric dilution of precision
Position info
Position info
Position info
position.source.enum
Number of position source
Position info
recovery.mode.status
Recovery Mode On/Off
Log reasons
Log reasons
trip.average.wakeup.number
Average Wakeups Per Trip
Device Counters
Device Counters
Log reasons
wifi.channel
WiFi channel number
Wi-Fi data
wifi.failed.scans
Count of failed Wi-Fi scans
Device Counters
Wi-Fi data
Wi-Fi data
wifi.successful.scans
Device Counters
