Mictrack MT600-NB
Mictrack MT600-NB is a Cat. M1 & NB-IoT vehicle GPS tracker with low power consumption. The device features ACC switch status report, geofencing, overspeeding alert, SOS report, remote fuel/ignition cut off, external power cut off alarm, low battery alarm, power saving mode, 500 mAh battery, and more.
Parameters (39)
Mictrack MT600-NB
Flespi parses telemetry data from your Mictrack MT600-NB into a standardized JSON and lets you send commands to Mictrack MT600-NB via API.
    "device.type.id": "Mictrack MT600-NB",
    "protocol.id": "mictrack"
How to send commands to Mictrack MT600-NB?
backup.battery.voltage.status
car.battery.voltage
Car battery voltage
car.battery.voltage.status
Car battery voltage is low status
fuel.voltage
Fuel voltage
position.status
Position status: A - valid, V - invalid, L - last position
report.interval.time
Report interval time
payload: Command text to send
