Mictrack MT600 Plus
Mictrack MT600 Plus is a multifunctional 4G LTE GPS tracker with extended peripherals support (fuel sensor, temperature sensor, door sensor, siren, mic, and speaker). The device features an external speaker and microphone, two-way audio /listen-in, multiple alerts & reports, a 500 mAh battery, and more.
Parameters (39)
Mictrack MT600 Plus
Flespi parses telemetry data from your Mictrack MT600 Plus into a standardized JSON and lets you send commands to Mictrack MT600 Plus via API.
    "device.type.id": "Mictrack MT600 Plus",
    "protocol.id": "mictrack"
How to send commands to Mictrack MT600 Plus?
backup.battery.voltage.status
car.battery.voltage
Car battery voltage
car.battery.voltage.status
Car battery voltage is low status
fuel.voltage
Fuel voltage
position.status
Position status: A - valid, V - invalid, L - last position
report.interval.time
Report interval time
payload: Command text to send
