AOVX VL300
AOVX VL300 is a 4G vehicle and trailer GPS tracker with ACC ignition, relay control, and multiple GPIOs. The device features global Cat. M1/NB-IoT connectivity, BLE 5.0, optional 90 mAh Li-Pol battery, and more.
Parameters (64)
Settings (18)
AOVX VL300
Flespi parses telemetry data from your AOVX VL300 into a standardized JSON and lets you send commands to AOVX VL300 via API.
    "device.type.id": "AOVX VL300",
    "protocol.id": "aovx"
How to send commands to AOVX VL300?
battery.charging.state
ble.sensors
data.type.enum
Data type code
Message ID
gpio.input
GPIO Input channel
gpio.output
GPIO Output channel
sensor.humidity.limit.max
Humidity sensor limit (max)
sensor.humidity.limit.min
Humidity sensor limit (min)
sensor.illuminance.limit.max
sensor.temperature.limit.max
sensor.temperature.limit.min
work.mode
Protocol-specific work mode
APN configuration
password: APN password
username: APN username
Bluetooth configuration
timeout: Nodes Timeout
max_nodes: Max Nodes
scan_time: Single scan time
work_mode: Work Mode
report_mask: Report Mask
Device configuration
device
timezone: Timezone
identifier: Device ID
Device information
Device information
iccid: ICCID
device_model: Device Model
factory
GNSS configuration
gnss
Heartbeat interval
heartbeat_interval
Set heartbeat interval
interval: Heartbeat interval
NTP configuration
ntp
NTP configuration
port: NTP server port
server: NTP server address
odometer configuration
value: Odometer
OTA upgrade
ota_upgrade
params: OTA params
Report configuration
report
Report interval configuration
report_interval
run: Run mode
sleep: Sleep mode
Device restart
restart
Server
Server configuration
ack: Server ACK Enable
protocol: Protocol Type
Speed configuration
speed
Speed configuration
max: Maximum
over_speed: Over-speed
Turn angle configuration
turn_angle
angle: Turn angle
Voltage configuration
voltage
run: Run voltage
stop: Stop voltage
sleep: Sleep voltage
WiFi configuration
wifi
WiFi configuration
max_ap: Max AP
