Data field %AI,
Data field %AV
ain.voltage.high.status
Data field %AG
Data field %PK
Data field %BV
Data field %BL
Data field %BT
Data field %JH
Data field %JH
can.cruise.control.mileage
Data field %JN
Data field %JO
can.driver.card.status
CAN-bus driver card presence
Data field %JO
Data field %JO
can.driver.work.state.enum
Data field %JO
Data field %DC
can.dtc.pending.status
Data field %PD
Data field %JO
Data field %JO
Data field %EH
Data field %ET
can.fms.diagnostic.state
Data field %JO
can.fms.request.state
Data field %JO
Data field %FC
Data field %JH
Data field %JH
Data field %JN
Data field %JO
can.handling.info.status
CAN-bus handling information
Data field %JO
Data field %IA
Data field %MP
can.j1708.abs.state
Data field %ZO
Data field %ZO
can.j1708.boost.pressure
CAN J1708 boost pressure
Data field %ZO
can.j1708.brake.pressure
Data field %ZO
Data field %ZO
Data field %ZO
can.j1708.brake.stroke.state
Data field %ZO
can.j1708.cargo.weight
N
CAN J1708 cargo weight
Data field %ZH
Data field %ZO
Data field %ZO
can.j1708.engine.load
CAN J1708 engine load
Data field %ZO
can.j1708.engine.motorhours
Data field %ZL
can.j1708.engine.oil.pressure
CAN J1708 engine oil pressure
Data field %ZO
can.j1708.engine.rpm
CAN J1708 engine RPM
Data field %ZH
can.j1708.fuel.level
CAN J1708 fuel level
Data field %ZO
can.j1708.fuel.rate
10e-6L/s
Data field %ZH
can.j1708.fuel.used
CAN J1708 total fuel used
Data field %ZL
can.j1708.fuel.used.idle
Data field %ZL
can.j1708.idle.motorhours
CAN J1708 total idle hours
Data field %ZL
Data field %ZO
can.j1708.mil.state
Data field %ZO
can.j1708.parking.brake.state
Data field %ZO
Data field %ZO
can.j1708.vehicle.mileage
CAN J1708 vehicle mileage
Data field %ZL
can.j1708.vehicle.motorhours
CAN J1708 total vehicle hours
Data field %ZL
can.j1708.vehicle.speed
CAN J1708 vehicle speed
Data field %ZO
can.j1708.vehicle.vin
CAN J1708 vehicle VIN
Data field %ZS
can.j1939.engine.fuel.total
Data field %JL
can.j1939.engine.motorhours
Data field %JL
can.j1939.engine.rpm
CAN J1939 engine RPM
Data field %JH
can.j1939.fuel.consumed
Data field %JL
can.j1939.software.version
CAN-bus J1939 FMS SW-version
Data field %JS
can.j1939.vehicle.mileage
CAN J1939 vehicle mileage
Data field %JL
can.j1939.vehicle.speed
CAN J1939 vehicle speed
Data field %JH
can.j1939.vehicle.vin
CAN J1939 vehicle VIN
Data field %JS
Data field %MF
Data field %ML
can.movement.status
Data field %JO
can.overspeeding.status
CAN-bus ovespeeding status
Data field %JO
CAN brake pedal pressed
Data field %JO
Data field %JO
can.pending.dtc
Data field %PD
Data field %JO
Data field %JO
Data field %JN
Data field %JN
Data field %JO
Data field %JH
can.tacho.event
Data field %JO
can.tacho.performance
Data field %JO
Data field %JH
Data field %JO
Data field %JN
Data field %EO
Data field %ES
Data field %PC
Data field %IN
Data field %OP
Data field %DD,
Data field %JS
Data field %EG
Data field %EH
external.powersource.level
Data field %BP
Data field %PS
Data field %MV
Data field %FL
Data field %FU
Data field %GF
Data field %SS
Data field %SS
Data field %SS
Data field %SF
Data field %SS
Data field %CG
Data field %CE
gsm.home.network.event
Data field %CR
Data field %JD
Data field %LC
Data field %CN
Data field %CN
Data field %CN
gsm.preferred.network.status
Data field %PF
gsm.roaming.network.event
Data field %RO
Data field %RL
Data field %GQ
Data field %CD
Data field %CM
Data field %GS
gsm.state.enum.description
Data field %GS
Data field %HA
Data field %HB
Data field %HC
Data field %DL
impact.event
Impact event
Data field %IP
main.power.low.status
Main power low status
Data field %PL
Data field %DT
Data field %MT
Data field %GR
Data field %OC
Data field %SD
Data field %AT
Data field %HD
Data field %HP
Data field %LA
Data field %LG
Data field %GP,
Data field %SA
Data field %VS
Data field %GP
Data field %RD
Data field %GV
Data field %GV
Data field %GV
segment.max.engine.load.level
Data field %EL
segment.max.engine.rpm
Maximum engine RPM on segment
Data field %RP
segment.max.position.speed
Maximum speed on segment
Data field %SM
Data field %TR
Data field %GV
send.timestamp
Message send timestamp
Data field %ST
Data field %HT
Data field %HT,
Data field %TP
Data field %CS
degree
Data field %TL
Data field %RT
total.acceleration
Data field %JF
Data field %TW
Data field %WH
Data field %EO,
Data field %OD
Data field %VN
Data field %MA
