Cargo Spy (CS2)
Cargo Spy (CS2) is a magnet asset GPS tracker for various applications such as package delivery, hidden tracking of vehicles, long distance transportation, endurance racing etc. The device features a 6000mAh Li-ion rechargeable battery that lasts for up to 1 year in guard mode and 2000 km in motion mode, movement sensor, FOTA, Bluetooth, IP65 waterproof casing, and more.
Parameters (45)
Settings (13)
Cargo Spy (CS2)
Flespi parses telemetry data from your Cargo Spy (CS2) into a standardized JSON and lets you send commands to Cargo Spy (CS2) via API.
    "device.type.id": "Cargo Spy (CS2)",
    "protocol.id": "cargo"
How to send commands to Cargo Spy (CS2)?
AVL ID 9
case.status
Case opened status
AVL ID 7
AVL ID 4
AVL ID 1
AVL ID 66
AVL ID 130
AVL ID 132
AVL ID 205
AVL ID 206
AVL ID 133
AVL ID 24
AVL ID 69
AVL ID 109,
AVL ID 2
trailer.id
Trailer ID
AVL ID 135
AVL ID 199
APN SIM1
apn1
APN settings for SIM1
APN SIM2
apn2
APN settings for SIM2
Block/Unblock Engine
block_engine
Block/unblock engine
block: Block
Bluetooth
Enable/disable bluetooth.
Clear Buffer
clear_buffer
Configuration
config
info: Configuration
Location
location
Query device location
info: Location
Reboot the device.
Reset
Sensors
sensors
Query device sensors state
info: Sensors
Backend Server
Backend server setup
Mode
track3
Tracking configuration
Query device version
info: Version
Query device configuration
{"payload":"@info:conf@"}
custom_no_response
