agps.position.valid
AGPS data valid
Command 0x01 with Key 0x24,
Command 0x03 with Key 0x24
alarm.panic.start
Panic alarm event started
Command 0x01 with Key 0x02
alarm.panic.stop
Panic alarm event ended
amber.alarm.start
Amber alarm event started
amber.alarm.stop
Amber alarm event stopped
Command 0x01 with Key 0x02,
battery.full
Battery fully charged
Command 0x02 with Key 0x14,
beacon.absence.status
Beacon absence alarm status
beacon.come.home.alarm
Beacon come home alert
beacon.leave.home.alarm
Beacon leave home alert
Command 0x01 with Key 0x28,
Command 0x01 with Key 0x2C
ble.disconnected.alarm
BLE disconnected alert
Command 0x01 with Key 0x23,
Command 0x01 with Key 0x26
call.duration
Call duration
Command 0x01 with Key 0x25
call.return.code
Call return code
call.status
Call status bit
call.type
Call type
call.type.enum
Call type number
Command 0x03 with Key 0x30
device.reboot
Device reboot status
Command 0x02 with Key 0x13
Command 0x01 with Key 0x03
Command 0x01
fall.alarm.start
Fall alarm event started
fall.alarm.status
Fall alarm status
fall.alarm.stop
Fall alarm event stopped
Command 0x01 with Key 0x20
Command 0x01 with Key 0x21,
Command 0x01 with Key 0x29,
Command 0x01 with Key 0x2B,
Command 0x03 with Key 0x21
Command 0x01 with Key 0x04
heart.rate
bpm
Heart rate
Command 0x01 with Key 0x40
heart.rate.trust.level
Heart rate trust level
indoor.status
Indoor status flag
location.source.beacon
Location is obtained by Beacon
location.source.bluetooth
Location is obtained by Bluetooth
location.source.gps
Location is obtained via GPS
location.source.gsm
Location is obtained by Mobile network (GSM, 3G, 4G, LTE, 5G, ...) cell towers
location.source.smart
Smart locating flag
location.source.wifi
Location is obtained by Wi-Fi
no.motion.alarm
No motion alarm
one.day.upload
One day upload alarm flag
pet.activity
Pet activity
Command 0x01 with Key 0x31
position.address
Location Address
Command 0x01 with Key 0x2A
Command 0x01 with Key 0x20,
Command 0x01 with Key 0x26,
Command 0x01 with Key 0x27
Command 0x01 with Key 0x27,
side.call.button
Side call button alarm
spo2.rate
SPO2 rate
Command 0x01 with Key 0x41
spo2.rate.trust.level
SPO2 rate trust level
startup.alarm
Startup alarm event
Command 0x01 with Key 0x30
tilt.status
Command 0x01 with Key 0x19,
Command 0x01 with Key 0x25,
Command 0x01 with Key 0x2A,
Command 0x01 with Key 0x30,
Command 0x01 with Key 0x31,
Command 0x01 with Key 0x40,
Command 0x01 with Key 0x41,
welfare.alarm.start
Welfare alarm event started
welfare.alarm.stop
Welfare alarm event stopped
wifi.home.status
Home Wi-Fi location flag
Command 0x01 with Key 0x22,
wifi.status
Wifi connection status
