Tag 0x47
Tag 0x50...0x57,
Tag 0x78...0x7D
Tag 0x40
Tag 0x40
Tag 0x42
before.maintenance.hours
Hours up to next maintenance
Tag 0x5B
beidou.average.snr
Extended Tag 0x90
beidou.max.snr
Extended Tag 0x90
Extended Tag 0x90
beidou.visible.satellites
Extended Tag 0x90
bluetooth.sensor.value
Extended Tag 0x21...0x60
Tag 0x47
bump.acceleration
Acceleration on bumps
Tag 0x47
can.16bit.value
Custom 16bit CAN value
Tag 0xB0...0xB9,
Tag 0xD6...0xDA
can.32bit.value
Custom 32bit CAN value
Tag 0xDB...0xDF,
Tag 0xF0...0xF9
can.8bit.value
Custom 8bit CAN value
Tag 0xA0...0xAF,
Tag 0xC4...0xD2
Extended Tag 0x27BD
Extended Tag 0x2807
Extended Tag 0x2774
Extended Tag 0x27BF
Extended Tag 0x27CE,
Tag 0xC1
can.engine.rpm.limit
Extended Tag 0x2A92
Tag 0xC1
Tag 0xC0
Tag 0xC1
Extended Tag 0x27BE
can.sensor.value.b
CAN B sensor value
Tag 0xC3
Tag 0xC2
cell.location.error.meters
Tag 0x35
connection.state
Connection state
Tag 0x48
datacold500.engine.motorhours
DataCOLD500 engine motorhours
Tag 0x5B
Tag 0x5B
datacold500.total.motorhours
Tag 0x5B
Tag 0x43
Tag 0x46
dosimeter.dbgc11d.ader
sv/h
DBG-C11D dosimeter ADER value
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x5D
Tag 0x45
Tag 0x40
euroscan.diesel.motorhours
EuroScan diesel motorhours
Tag 0x5B
euroscan.electric.motorhours
EuroScan electric motorhours
Tag 0x5B
euroscan.standby.motorhours
EuroScan standby motorhours
Tag 0x5B
Tag 0x41
Tag 0x40
galileo.average.snr
Extended Tag 0x91
galileo.max.snr
Extended Tag 0x91
galileo.position.satellites
Extended Tag 0x91
galileo.visible.satellites
Extended Tag 0x91
Tag 0x40
glonass.average.snr
Extended Tag 0x8F
glonass.max.snr
Extended Tag 0x8F
glonass.position.satellites
Extended Tag 0x8F
glonass.visible.satellites
Extended Tag 0x8F
Tag 0x40
gnss.type
Tag 0x40
gps.average.snr
Extended Tag 0x8E
gps.max.snr
Extended Tag 0x8E
Extended Tag 0x8E
gps.visible.satellites
Extended Tag 0x8E
Extended Tag 0x81
Tag 0x48
Extended Tag 0x82
Extended Tag 0x83
Extended Tag 0x84
Tag 0x48
Extended Tag 0x85
Tag 0x40
Extended Tag 0x94
Extended Tag 0x92
Tag 0x40
hardware.version.enum
Hardware version enum
Tag 0x01
Extended Tag 0xFD,
Extended Tag 0xFE,
Tag 0x90,
Tag 0xD3
Tag 0x40
ibutton.connection.status
iButton key connected status
Tag 0xD5
incline.event
Incline exceeds allowed level
Tag 0x40
Tag 0x40
Tag 0x40
modbus.sensor.value
Extended Tag 0x01...0x20,
Extended Tag 0x61...0x80
Tag 0x40
network.type.enum
Transmission channel
Tag 0x49
Tag 0x80...0x87
Tag 0x80...0x87
Tag 0x34
Tag 0x33
Tag 0x35
Tag 0x30
Tag 0x30
Tag 0x33
Tag 0x30
Tag 0x10
refrigerator.alarm.enum
Refrigerator alarm code
Tag 0x5B
refrigerator.alarm.type.enum
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.din
Tag 0x5B
Tag 0x5B
refrigerator.emergency.status
Refrigerator emergency status
Tag 0x5B
refrigerator.engine.mode
Tag 0x5B
refrigerator.engine.mode.enum
Tag 0x5B
refrigerator.engine.rpm
Refrigerator engine RPM
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.operate.mode
Tag 0x5B
Tag 0x5B
Tag 0x5B
Tag 0x5B
Tag 0x5B
refrigerator.set.temperature
Tag 0x5B
refrigerator.troublecode.enum
Tag 0x5B
rep500.counter.value
Tag 0x5A
Extended Tag 0xFC
rs232.sensor.value
Custom RS232 sensor value
Tag 0x58,
Tag 0x59
Tag 0x63...0x6F,
Tag 0x8A...0x8C
Tag 0x60...0x62,
Tag 0x63...0x6F
Extended Tag 0x86...0x8D,
Tag 0x70...0x77
sensor.temperature.id
ID os temperature sensor
Tag 0x40
sim.card.slot
Currently used SIM card slot
Extended Tag 0x93
software.version.enum
Software version enum
Tag 0x02
thermoking.accident.enum
ThermoKing accident enum
Tag 0x5B
Tag 0x5B
thermoking.engine.motorhours
ThermoKing engine motorhours
Tag 0x5B
thermoking.total.motorhours
Tag 0x5B
Tag 0x20,
Tag 0x21
Tag 0x5C
Tag 0x5C
tire.sensor.connection.status
Tire sensor connection status
Tag 0x5C
tire.sensor.reason.enum
Tag 0x5C
Tag 0x5C
Tag 0x47
user.data.hex
User data array in HEX
Tag 0xEA
user.data.value
User data value
Tag 0xE2...0xE9
Tag 0xD4
Tag 0x44
Tag 0x44
Tag 0x44
Authorize phone number
add_number
backend_server2
CAN-bus regime
canbus
Set up CAN-BUS connection
Clear EasyLogic script
easylogic_clear
username: EasyLogic Username
scriptname: Script name
easylogic_get
List EasyLogic scripts installed on deivce. Common size of scripts must be less than 400KB
Set EasyLogic script
easylogic_set
Setting operates with EasyLogic script used to confiugre internal device logic
Signaling
guard
Enable/disable signaling
Head packet parameters
headpack1
tag_01: hardware version
tag_02: firmware version
tag_03: IMEI
tag_04: Device ID
tag_05: Message ID in archive
tag_06: Time
tag_07: Coordinates, sattelites, postion correctness
tag_08: Speed and direction
tag_09: Height
tag_10: HDOP
tag_11: Device state
tag_12: Supply voltage
tag_13: Battery voltage
tag_14: Device temperature
tag_15: Acceleration
tag_16: Output states
tag_17: Input states
tag_18: Input value 0.
tag_19: Input value 1.
tag_20: Input value 2.
tag_21: Input value 3.
tag_22: RS232 0
tag_23: RS232 1
tag_32: First key iButton ID
Main packet parameters
mainpack1
tag_03: IMEI
tag_04: Device ID
tag_06: Time
tag_09: Height
tag_10: HDOP
tag_22: RS232 0
tag_23: RS232 1
GSM Network Setup for SIM0
network_sim0
GSM Network Setup for SIM1
network_sim1
Output 0
output0
Switching external trigger 2. By default trigger is switched off. State is hold in non-volatile memory, will be restored after reboot.
Output 3
output3
Switching external trigger 3. By default trigger is switched off. State is hold in non-volatile memory, will be restored after reboot.
Alert Phones
phones
Phone numbers to send alerts
number1: Phone Number 1
number2: Phone Number 2
number3: Phone Number 3
number4: Phone Number 4
Reboot Device
Accelerometer
sacc
Accelerometer signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
photo: Picture
GPS
sgps
GPS signaling settings
sms: SMS
ring: Call
type: Mode
radius: Radius
timeout: Time
Shock
shock
Shock and incline detection settings
sens: Sensibility
type: Mode
General Settings
sign
General signalling settings
useib: Use iButton Keys
gwtime: Green Wave Timeout
datimeout: Drop Alarm Timeout
DIN1
sin0
Digital input 1 signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
delay: Delay
photo: Picture
DIN2
sin1
Digital input 2 signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
delay: Delay
photo: Picture
DIN3
sin2
Digital input 3 signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
delay: Delay
photo: Picture
DIN4
sin3
Digital input 4 signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
delay: Delay
photo: Picture
DIN5
sin4
Digital input 5 signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
delay: Delay
photo: Picture
DIN6
sin5
Digital input 6 signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
delay: Delay
photo: Picture
DIN7
sin6
Digital input 7 signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
delay: Delay
photo: Picture
DIN8
sin7
Digital input 8 signaling settings
msg: Message
sms: SMS
ring: Call
type: Mode
delay: Delay
photo: Picture
DOUT1
sout0
Digital output 1 signaling settings
amode: Alarm
dmode: Signaling Disabling
emode: Signaling Enabling
DOUT2
sout1
Digital output 2 signaling settings
amode: Alarm
DOUT3
sout2
Digital output 3 signaling settings
amode: Alarm
DOUT4
sout3
Digital output 4 signaling settings
amode: Alarm
Tracking parameters
tracking
dist: Distance
speed: Minimum Speed
delta_speed: Overspeeding
Data recording interval
wr_period
move_int: In Motion
stop_int: At Stop
