Navtelecom Signal S-2550
Navtelecom SIGNAL S-2550 is a simplified version of the SIGNAL S-2551 and is designed to solve simple tasks of vehicle monitoring. The device retained the ability to read data from the CAN bus of the vehicle using CANLog, and the ability to connect pulse, analog and digital (RS-232) fuel level sensors. The device also has a built-in battery.
Parameters (212)
Settings (3)
Flespi parses telemetry data from your Navtelecom Signal S-2550 into a standardized JSON and lets you send commands to Navtelecom Signal S-2550 via API.
    "device.type.id": "Navtelecom Signal S-2550",
    "protocol.id": "navtelecom"
How to send commands to Navtelecom Signal S-2550?
acceleration.threshold.status
accelerometer.sh1.status
accelerometer.sh2.status
accelerometer.sh3.status
accelerometer.sh4.status
accelerometer.wakeup.status
bluetooth.configurator.status
braking.threshold.status
bus.announcer.geofence.inside
bus.announcer.status
Bus announcer status
bus.counter.passengers
Bus passengers counter
bus.geofence.id
ID of last bus geofence
bus.route.id
ID of last bus route
bus.stop.id
ID of last bus stop
camera.automatic.mode.status
camera.error.event
Error working with camera
can.indicators.bitmask
can.mil.bitmask
can.security.bitmask
can.security.event.code
case.status
Case opened status
compass.position.satellites
connection.state
Connection state
device.model.enum
display.driver.state.enum
display.read.message.id
doris.position.satellites
engine.generator.status
extnav.position.altitude
extnav.position.direction
extnav.position.latitude
extnav.position.longitude
extnav.position.satellites
extnav.status
freezer.active.alarm.data
Active alarms data
freezer.active.alarm.number
freezer.battery.current
Freezer battery DC current
freezer.engine.motorhours
freezer.engine.rpm
Freezer engine RPM
freezer.engine.standby.status
freezer.operating.mode
Freezer operating mode
freezer.type
freezer.zone1.temperature
Freezer zone 1 temperature
freezer.zone2.temperature
Freezer zone 2 temperature
freezer.zone3.temperature
Freezer zone 3 temperature
fuel.flow.meter.fuel.consumed
fuel.flow.meter.rate
l/h
l/h
fuel.flow.meters.faults.state
fuel.flow.meter.state
Fuel flow meter state bitmask
l/h
galileo.position.satellites
glonass.position.satellites
gsm.timestamp
high.precision.humidity.level
high.precision.temperature
inertial.navigation.status
iridium.status
Iridium module status
irnss.position.satellites
left.turn.threshold.status
local.vertical.tilt.angle
motorhours.under.load
motorhours.without.load
overspeeding.threshold.status
pitch.angle
qzss.position.satellites
right.turn.threshold.status
roll.angle
rs232.lls.error
rs232.lls.temperature
rs485.lls.error
rs485.lls.frequency
rsc.rfu.status
RCS/RFU status
segment.valid.position.count
sensor.frequency
Frequency sensor value
sensor.uint16.value
sensor.uint32.value
sensor.uint64.value
sensor.uint8.value
server1.connection.status
Server 1 connection status
server2.connection.status
Server 2 connection status
server3.connection.status
Server 3 connection status
tacho.connection.error.status
tacho.driver.activity.enum
Tacho driver card presence
tacho.engine.ignition.status
Tachograph ignition state
tacho.ferry.train.enum
Tacho ferry/train status enum
tacho.mode.enum
Tachograph mode enum
tacho.na.enum
test.mode.status
threshold.exceeding.duration
timestamp.increment
timestamp.sync.status
touch.memory.id
Touch Memory Key ID
usb.connection.status
addr: Server Address
dc_id: Dispatch Center ID
obj_id: Object ID
SIM card network configuration
GPRS Connection configuration for the SIM card
pass: Password
login: Login
Reboot the device.
{"text":"*?S"}
{"text":"*!SETOUT 1Y,2N"}
{"text":"*?V"}
Set output line state
output
Set output line 1...4 state
line: Line number
state: Line state
Turn on line 1
{"line":1,"state":true}
