Queclink GL300N
The water resistant Queclink GL300N asset tracker is designed for lone workers, vehicle, pet and asset tracking applications. The ergonomically designed button makes the GL300 ideal for applications requiring rapid emergency alert or instant geo-fencing based on current location. Asset trackers within the series support 2G GSM, LTE CAT-M1 (eMTC), LTE CAT-M2 (NB-IoT) on many bands supporting North American and European Cellular Operators.
Parameters (427)
Settings (6)
Queclink GL300N
Flespi parses telemetry data from your Queclink GL300N into a standardized JSON and lets you send commands to Queclink GL300N via API.
    "device.type.id": "Queclink GL300N",
How to send commands to Queclink GL300N?
Report GTTEM
Report GTTEM
Report GTTEM
The car synchronization state
can.doors.boot.status
The engine torque
CAN gaseous fuel level
CAN gaseous fuel volume
CAN brake pedal pressed
CAN charge state
kW/h
kW/h
kW/h
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTCRD
Report GTTEM
Report GTTSW
Report GTFTP
Report GTFTP
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTTEM
Report GTTEM
jamming.state
messages.beffered.count
Report GTTEM
Network state
position.fix.type.enum
Report GTGPS
record
Record, indexed parameter
report.reason.enum
SIM card state
tacho.apdu.payload.hex
Tachograph APDU data
tacho.apdu.seqnum
Tacho driver card presence
Tachograph overspeed signal
Report GTTOW
Report GTSTT
Fixed Report
fixed_report_gl
mode: Working Mode
corner: Corner Report
end_time: End Time
movement: Movement Detect Mode
start_time: Start Time
check_interval: GPS Check Interval
network_gsm
network_mode: Network Mode
Non-Movement Behavior
non_movement
Non-Movement detection and behavior
movement: Movement
send_interval: Send Interval
Custom Command
