Queclink GV500
Queclink GV500 is a vehicle tracking device that plugs into a vehicle's OBDII port. Its compact design allows easy installation. Its internal OBD reader can obtain information from the vehicle's on-board computer and relay it over GPRS networks.
Parameters (427)
Settings (15)
Queclink GV500
Flespi parses telemetry data from your Queclink GV500 into a standardized JSON and lets you send commands to Queclink GV500 via API.
    "device.type.id": "Queclink GV500",
How to send commands to Queclink GV500?
Report GTTEM
Report GTTEM
Report GTTEM
The car synchronization state
can.doors.boot.status
The engine torque
CAN gaseous fuel level
CAN gaseous fuel volume
CAN brake pedal pressed
CAN charge state
kW/h
kW/h
kW/h
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTCRD
Report GTTEM
Report GTTSW
Report GTFTP
Report GTFTP
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTTEM
Report GTTEM
jamming.state
messages.beffered.count
Report GTTEM
Network state
position.fix.type.enum
Report GTGPS
record
Record, indexed parameter
report.reason.enum
SIM card state
tacho.apdu.payload.hex
Tachograph APDU data
tacho.apdu.seqnum
Tacho driver card presence
Tachograph overspeed signal
Report GTTOW
Report GTSTT
Device Parameters
config_gv500
agps: AGPS Mode
antenna: GPS Antenna Mode
led_mode: LEDs Working Mode
odometer: Odometer
pwr_mode: Power Saving Mode
sleep_mode: Sleep Mode
device_name: Device Name
no_ign_mode: No Ignition Mode
gps_lost_time: GPS Lost Time
Events
events_gv500
pfa_event: Power off event
pna_event: Power on event
External Power Supply Alarm
ext_power_alarm_without_output
sync: Sync With FRI
debounce: Debounce Time
max_threshold: Max Threshold
min_threshold: Min Threshold
Fixed Report
fixed_report_gv500
mode: Working Mode
corner: Corner Report
time_range: Time Range
GSM Reports
gsm_reports_gv500
mode: GSM Reports Mode
reports: Select reports
network_gsm
network_mode: Network Mode
OBDII Configuration
obd_config_gv500
OBDII configuration settings
fuel: Fuel Type
sync: Monitor Sync Protocol
check: OBD Reading
report: OBD Report
debounce: IGF Debounce Time
jes_mask: Journey Summary GTJES
event_mask: Event reports
igf_report: OBD IGF Report
report_mask: OBD Report Composition
displacement: Displacement
init_mileage: OBD Initial Mileage
Report Composition
report_gv500
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
vin_enable: VIN
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Tow Alarm
tow_alarm_without_output
Tow alarm configuration
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
virt_ign_accel_gv500
Accelerometer (motion status) virtual ignition settings
rest_timeout: Rest Duration
motion_timeout: Motion Validity
Virtual Ignition Mode
virt_ign_mode_gv500
Virtual ignition working mode
mode: Working Mode
Voltage Virtual Ignition
virt_ign_volt_gv500
Voltage virtual ignition settings
debounce: Debounce
on_voltage: Ignition ON Voltage
off_voltage: Ignition OFF Voltage
Custom Command
