Report GTTEM
Report GTTEM
Report GTTEM
The car synchronization state
can.doors.boot.status
The engine torque
CAN gaseous fuel level
CAN gaseous fuel volume
CAN brake pedal pressed
CAN charge state
kW/h
kW/h
kW/h
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTCRD
Report GTTEM
Report GTTSW
Report GTFTP
Report GTFTP
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTTEM
Report GTTEM
jamming.state
messages.beffered.count
Report GTTEM
Network state
position.fix.type.enum
Report GTGPS
record
Record, indexed parameter
report.reason.enum
SIM card state
tacho.apdu.payload.hex
Tachograph APDU data
tacho.apdu.seqnum
Tacho driver card presence
Tachograph overspeed signal
Report GTTOW
Report GTSTT
