Queclink GV55N
Queclink GV55 is a mini GPS tracker designed for a wide variety of vehicle tracking applications. It has multiple I/O interfaces that can be used for monitoring or controlling external devices. Its built-in GPS receiver has superior sensitivity and fast time to first fix. Its quad-band GPRS/GSM subsystem supports 850/900/1800/1900 MHz allowing the GV55's location to be monitored in real-time or periodically tracked by a backend server and mobile devices.
Parameters (427)
Settings (4)
Queclink GV55N
Flespi parses telemetry data from your Queclink GV55N into a standardized JSON and lets you send commands to Queclink GV55N via API.
    "device.type.id": "Queclink GV55N",
How to send commands to Queclink GV55N?
Report GTTEM
Report GTTEM
Report GTTEM
The car synchronization state
can.doors.boot.status
The engine torque
CAN gaseous fuel level
CAN gaseous fuel volume
CAN brake pedal pressed
CAN charge state
kW/h
kW/h
kW/h
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTCRD
Report GTTEM
Report GTTSW
Report GTFTP
Report GTFTP
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTTEM
Report GTTEM
jamming.state
messages.beffered.count
Report GTTEM
Network state
position.fix.type.enum
Report GTGPS
record
Record, indexed parameter
report.reason.enum
SIM card state
tacho.apdu.payload.hex
Tachograph APDU data
tacho.apdu.seqnum
Tacho driver card presence
Tachograph overspeed signal
Report GTTOW
Report GTSTT
network_gsm
network_mode: Network Mode
Custom Command
