Queclink GV75W
Queclink GW75W is an advanced waterproof GPS tracker for monitoring and control of external devices. GW75W supports the triple-band WCDMA and quad-band GSM/GPRS. The tracker features the internal 3-axis accelerometer that enables driving behavior monitoring, power saving, and motion detection.
Parameters (427)
Settings (23)
Queclink GV75W
Flespi parses telemetry data from your Queclink GV75W into a standardized JSON and lets you send commands to Queclink GV75W via API.
    "device.type.id": "Queclink GV75W",
How to send commands to Queclink GV75W?
Report GTTEM
Report GTTEM
Report GTTEM
The car synchronization state
can.doors.boot.status
The engine torque
CAN gaseous fuel level
CAN gaseous fuel volume
CAN brake pedal pressed
CAN charge state
kW/h
kW/h
kW/h
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTCRD
Report GTTEM
Report GTTSW
Report GTFTP
Report GTFTP
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTBND,
Report GTEST,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTTEM
Report GTTEM
jamming.state
messages.beffered.count
Report GTTEM
Network state
position.fix.type.enum
Report GTGPS
record
Record, indexed parameter
report.reason.enum
SIM card state
tacho.apdu.payload.hex
Tachograph APDU data
tacho.apdu.seqnum
Tacho driver card presence
Tachograph overspeed signal
Report GTTOW
Report GTSTT
Get Internal Battery Level
battery_level
Get CAN Information
can_access_info
Get CAN Version
can_version
Get Connectivity Info
conn_info
Terminal Factory Reset
factory_reset
Get Fuel Gauge Information
fuel_gauge_access_info
Get GNSS Info
gnss_info
Get GPS Signal Level
gps_signal
Digital Input
inputs2
Digital Inputs Control
input1: Input #1
ignition: Ignition Input
Get I/O Status
io_status
Get Location
location
network_gsm
network_mode: Network Mode
Get Network Info
network_info
Digital Output 1
gtdos: GTDOS Report
Digital Output 2
wave: Wave Shape
Power Off
power_off
Reset Terminal
Get SIM ICCID
sim_iccid
Get Terminal Version
terminal_version
Get Time Zone
time_zone
Custom Command
