Sierra Wireless GNX-6
Sierra Wireless GNX-6 GPS tracker is an all-in-one 2G/3G GPS tracker with CAN support. The device features auto-calibrating 3-axis accelerometer, CAN 1708/1939, multiple I/O, Garmin FMI support, voltage protection, intelligent power management, low power Bluetooth 4.0, optional internal backup battery, and more.
Parameters (99)
Settings (4)
Flespi parses telemetry data from your Sierra Wireless GNX-6 into a standardized JSON and lets you send commands to Sierra Wireless GNX-6 via API.
    "device.type.id": "Sierra Wireless GNX-6",
    "protocol.id": "sierrawireless"
How to send commands to Sierra Wireless GNX-6?
report column ID 10
absolute.deceleration
report column ID 10
report column ID 42
report column ID 61
bluetooth.state
Bluetooth state
report column ID 141
report column ID 72
report column ID 56
can.derived.fuel.consumed
Derived fuel usage, read from CAN
report column ID 89
can.derived.gas.fuel.consumed
Derived natural gas fuel usage, read from CAN
report column ID 91
can.derived.vehicle.mileage
Derived vehicle mileage read from CAN
report column ID 93
report column ID 10
report column ID 74
report column ID 76
report column ID 112
report column ID 105
report column ID 104
report column ID 77
report column ID 108
report column ID 71
report column ID 100,
report column ID 99
report column ID 109
can.gas.fuel.economy
km/kg
CAN instantaneous natural gas fuel economy
report column ID 81
can.idle.fuel.consumed
report column ID 110
can.idle.gas.fuel.consumed
Total natural gas idle fuel used, read from CAN
report column ID 111
can.j1939.dm1.dtc.awl
report column ID 10
can.j1939.dm1.dtc.awl.flash
report column ID 10
can.j1939.dm1.dtc.mil
report column ID 10
can.j1939.dm1.dtc.mil.flash
report column ID 10
can.j1939.dm1.dtc.pl
report column ID 10
can.j1939.dm1.dtc.pl.flash
report column ID 10
can.j1939.dm1.dtc.rsl
report column ID 10
can.j1939.dm1.dtc.rsl.flash
report column ID 10
can.onboard.power.voltage
CAN onboard power voltage
report column ID 107
can.pending.dtc
report column ID 10
report column ID 65
can.seatbelt.state
Seat belt status, read from CAN
report column ID 114
report column ID 78
report column ID 113
report column ID 70
report column ID 75
cargo.temperature
report column ID 73
cornering.acceleration
Cornering acceleration
report column ID 10
crash.acceleration
Crash acceleration
report column ID 10
report column ID 10
report column ID 1
report column ID 50
report column ID 37,
report column ID 38,
report column ID 39,
report column ID 40
report column ID 79
report column ID 10,
report column ID 11
report column ID 10
report column ID 7
report column ID 41
report column ID 10
gnss.snr
dB
GNSS signal-to-noise ratio
report column ID 49
report column ID 48
report column ID 10
report column ID 10
report column ID 10
report column ID 82
report column ID 10
modem.sid
System identifier of the cellular modem
report column ID 43
report column ID 10
report column ID 44
report column ID 131
report column ID 130
report column ID 25,
report column ID 26
report column ID 17
report column ID 3
report column ID 4
report column ID 135
report column ID 46
report column ID 13,
report column ID 14
report column ID 36
report column ID 10
report column ID 10
report column ID 87
reset.event
Device reset event
report column ID 10
report column ID 90
segment.can.gas.fuel.consumed
Natural gas fuel amount consumed by vehicle on the last segment using CAN data
report column ID 92
report column ID 98
report column ID 57,
report column ID 58
report column ID 10
tilt.acceleration
Tilt accelerometer value
report column ID 10
tilt.event
Tilt event
report column ID 10
report column ID 2,
report column ID 36
report column ID 2,
report column ID 36,
report column ID 7
report column ID 97
report column ID 23,
report column ID 24
report column ID 31
report column ID 10
report column ID 47
Generic device information.
sim_iccid: SIM card ICCID
fw_version: Firmware Version
Network Setup
Configure network parameters
Report Columns
report_columns
Telematics report configuration
conf: Configuration
Custom Command
Send custom text to the device
payload: Command text
Query REPORT_COLUMNS(24) parameter value
{"payload":"DIAG PARAMS=24"}
