Syrus Lynx
Syrus Lynx is a 4G vehicle GPS tracker with multiple I/Os and global SIM. The device features LTE Cat-1 4G / 3G / 2G connectivity, tow alarm, driving behavior monitoring, remote vehicle immobilization, wireless Bluetooth temperature and humidity sensor support (BLE 5.2), 200 mAh battery, IP65 casing, and more.
Parameters (146)
Settings (5)
Syrus Lynx
Flespi parses telemetry data from your Syrus Lynx into a standardized JSON and lets you send commands to Syrus Lynx via API.
    "device.type.id": "Syrus Lynx",
    "protocol.id": "dct-syrus"
How to send commands to Syrus Lynx?
Report EV
acknowledgement.time
Acknowledge time. It is an accumulative time counter that it is incremented with the time that the application waits for the acknowledge of an event triggered
Report EV
Report EV,
backup.battery.status
Backup battery usage status
Report EV
Report EV
bytes.received
Number of bytes received by the device
Report EV
bytes.sent
Number of bytes transmitted by the device
Report EV
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
Report GTASC
counter.over.rpm
Value of over rpm counter
Report EV
counter.overspeeding
Value of over speed counter
Report EV
counter.value
Current value of counter
Report EV
Report GTCRG
Report GTASP,
Report GTSSP,
Report GTTSP,
Report RESP
Report EV,
Report EV,
Report EV,
Report EV,
error.code
Report ER
error.command
Configuration command that generated an error
Report ER
event.definition
Event definition
Report ED
Report EV,
Report TX
Report EV,
Report GTGSS
gprs.bearer.count
GPRS Bearer counter. Number of times that the GPRS bearer has changed from down to up
Report EV
gprs.count
GPRS counter. Number of times that the device has registered on GPRS network
Report EV
Report EV,
gsm.count
Mobile network (GSM, 3G, 4G, LTE, 5G, ...) counter. Number of times that the device has registered on the network
Report EV
Report EV,
Report EV,
Report EV,
Report EV,
Report EV
Report BUFF,
Report RESP
Report GTSTT
Report EV
packets.sent
Report EV
Report TX
Report EV,
position.corrected.status
Report EV,
Report TX
Report EV,
Report TX
position.fix.type
Report EV,
Report TX
Report EV,
Report EV,
Report TX
Report EV,
Report TX
Report EV
Report EV,
Report TX
Report EV
Report GTPNA
Report ACK,
Report BUFF,
Report RESP
Report BUFF,
Report GTASP,
Report GTSSP,
Report GTTSP,
Report RESP
Report GTTOW
retransmission.count
Retransmissions counter. Number of retries for transmitting events when the device does not received an ACK from server
Report EV
safe.shutdown.state
Safe shutdown state
Report GTSEI
Report GTASC
signal.name
Signal name
Report EV
signal.state
Current signal state
Report EV
signal.threshold
Signal threshold exceed
Report EV
signal.value
Current value of the variable associated with signal
Report EV
Report ACK,
Report BUFF,
Report EV,
Report RESP
Report ACK,
Report BUFF,
Report RESP
total.idle.seconds
Report EV
Report GTSTT
vehicle.altitude.change
Altitude change trend of the vehicle: 0: Unknown, 1: Vehicle going downhill, 2: There aren't significant altitude changes, 3: Vehicle going uphill
Report EV
Report GTASP,
Report GTSSP,
Report GTTSP,
vehicle.odometer
Report EV
Report GTSTT
Report GTEPS
Modem Information
modem_info
Modem versions information
sw_ver: Sofrware Version
time_zone
dst: Dayligh Saving
sign: Sign
hours_offset: Hour Offset
minutes_offset: Minute Offset
payload: Command text
