ThinkPower TE334A
ThinkPower TE334A is a 4G LTE Cat M1/NB1 advanced vehicle GPS tracker. The device features a 270 mAh battery, a water-resistant IP66 compliant casing, BLE 5.0, multiple interfaces for remote cut-off oil/fuel, ID Identification, fuel level monitor, SOS, etc., an internal 3-axis accelerometer for driver behavior detection, motion detection, and more.
Parameters (77)
Settings (36)
ThinkPower TE334A
Flespi parses telemetry data from your ThinkPower TE334A into a standardized JSON and lets you send commands to ThinkPower TE334A via API.
    "device.type.id": "ThinkPower TE334A",
    "protocol.id": "thinkpower"
How to send commands to ThinkPower TE334A?
ain.alarm.status
Analog input alarm status
can.engine.idle.duration
can.engine.oil.consumption
liter
can.idle.engine.rpm
can.idle.vehicle.speed
liter
gps.jamming.event
GPS signal jamming detected
gps.spoofed.event
GPS signal spoofing detected
lbs.location.status
ACC Report
acc_report
Configure APN parameters
Authorization Function
authorize
BLE Assets
ble
BLE assets configuration
mac1: BLE MAC1
mac2: BLE MAC2
mac3: BLE MAC3
mac4: BLE MAC4
mac5: BLE MAC5
mac6: BLE MAC6
mac7: BLE MAC7
mac8: BLE MAC8
timeout: BT Timeout
password: BT password
Device Info
device
Device IMEI
imei: Device IMEI
sw_version: Sofrware Version
Password
dev_pass
Device password
Valid Timeout
driver_valid
Driver ID validity timeout
Reset
factory
Factory reset
FW Update
ftp_server
url: URL
host: Server Address
username: Username
FW Upgrade
fw_upgrade
url: FW Server URL
G-sensor
g_sensor
G-sensor configuration
sensitivity: Sensitivity
x_threshold: X-axis Threshold
y_threshold: Y-axis Threshold
z_threshold: Z-axis Threshold
Heartbeat
heartbeat
Heartbeat interval
Humidity Alarm
humidity_alarm
High humidity alarm
iButton Function
ibutton
iButton function switch
Add iButton
ibutton_add
Set iButton ID
index: Index
Delete iButton
ibutton_delete
Delete iButton ID
index: Index
Ignition Off Timeout
ign_off
Low Power Report
low_power_report
Offline Mode
offline_mode
Disable/enable offline mode
enable: Activate
enable: Activate
Power Safe Mode
power_safe_mode
Relay Type
relay
The type of relay used
type: Type
Report Mode
report_mode
GPS report mode
distance: Distance
enable_on: Ignition On
enable_off: Ignition Off
enable_dist: Distance
interval_on: Interval On
enable_angle: Angle
interval_off: Interval Off
Response Timeout
response_timeout
Response timeout
RS232
rs232
type: Type
Speeding Alarm
seeping_alarm
Speeding alarm configuration
threshold: Speeding Threshold
Sensor
sensor
Sensor type configuration
type: Type
Serianet Mode
serianet_mode
Enable/disable serianet mode
Server Setup
Backend server configuration
SMS Switch
sms_switch
SMS function switch
SOS Alarm
sos_alarm
Enable/disable SOS alarm
SOS Number
sos_number
phone1: SOS Number 1
phone2: SOS Number 2
phone3: SOS Number 3
phone4: SOS Number 4
Location State Report
state_report
Temperature Alarm
temperature_alarm
High temperature alarm
Action reset
