Topflytech TLD1-DA
Topflytech TLD1-DA is an LTE Cat-M1 easy-to-install OBDII tracker. The device features high-gain GNSS and GSM antennas, FOTA support, eco-driving, green driving, accident and jamming detection, 2 IPs support, AGPS support, tire pressure sensor, Bluetooth 4.0, an internal Li-Pol battery, and more.
Parameters (107)
Settings (18)
Topflytech TLD1-DA
Flespi parses telemetry data from your Topflytech TLD1-DA into a standardized JSON and lets you send commands to Topflytech TLD1-DA via API.
    "device.type.id": "Topflytech TLD1-DA",
    "protocol.id": "topflytech"
How to send commands to Topflytech TLD1-DA?
accident.event
Accident event detected
Message Type 0x07
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Alarm Code 3,
Alarm Type 3,
Message Type 0x10,
Message Type 0x12
alarm.time
Message Type 0x13,
Message Type 0x14
Alarm Type 10
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Alarm Code 6,
Alarm Code 7,
Alarm Type 2,
Alarm Type 24
Message Type 0x02,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Message Type 0x10,
Message Type 0x12
ble.sensors
Message Type 0x10,
Message Type 0x12
Alarm Code 23,
Alarm Code 4
Message Type 0x09
Message Type 0x09
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04
Message Type 0x13,
Message Type 0x14
case.status
Case opened status
Alarm Code 2,
Alarm Code 22
crash.status
Alarm Code 10,
Alarm Code 27
Message Type 0x02,
Message Type 0x13,
Message Type 0x14
Alarm Code 25,
Alarm Code 8
device.temperature.low.status
Alarm Code 30,
Alarm Code 31
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
displacement.status
Alarm Code 1,
Alarm Code 21
Message Type 0x13
Message Type 0x10,
Message Type 0x12
Message Type 0x02,
Message Type 0x13,
Message Type 0x14
Alarm Code 16,
Alarm Code 17,
Bit14 of Digital I/O status,
Bit2 of Status,
Message Type 0x02,
Message Type 0x04,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x21,
Message Type 0x23,
Message Type 0x24
Message Type 0x13,
Message Type 0x14
Message Type 0x09
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Alarm Type 1,
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Alarm Code 24,
Alarm Code 5
Message Type 0x02,
Message Type 0x04
Alarm Code 14,
Alarm Code 15,
Alarm Type 5,
Alarm Type 6
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
gsm.earfcn
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Alarm Type 21,
Alarm Type 22
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
gsm.network.name
Message Type 0x05,
Message Type 0x11
gsm.pcid
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Message Type 0x05,
Message Type 0x11
Message Type 0x05,
Message Type 0x11
Message Type 0x05,
Message Type 0x06
Message Type 0x05,
Message Type 0x06
Message Type 0x06
Alarm Code 18,
Alarm Code 19,
Alarm Type 19,
Alarm Type 20
light.sensor.voltage
Front light sensor voltage
Message Type 0x02,
Message Type 0x24
lock.data
Lock data in HEX format
Message Type 0x17
lock.state
Message Type 0x17
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17
movement.distance
Message Type 0x13
Alarm Type 8
Message Type 0x02,
Message Type 0x24
onewire.payload.hex
Message Type 0x23
Message Type 0x23
Alarm Type 4,
Message Type 0x05
Message Type 0x81
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Alarm Code 20,
Alarm Code 29
Message Type 0x21
Message Type 0x21
solar.panel.charging.status
Solar panel charging device
Message Type 0x02,
Message Type 0x24
Message Type 0x02,
Message Type 0x24
tilt.status
Alarm Code 11,
Alarm Code 28
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x17,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24
time.valid.status
Time is accurate
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x17,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24
Alarm Type 7
usb.connection.status
Alarm Code 12,
Alarm Code 13
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Message Type 0x09,
Message Type 0x22
vibration.status
Alarm Code 26,
Alarm Code 9
Message Type 0x15,
Message Type 0x24
Message Type 0x15,
Message Type 0x24
Message Type 0x02,
Message Type 0x06,
Message Type 0x07
Message Type 0x02,
Message Type 0x06,
Message Type 0x07
Message Type 0x02,
Message Type 0x06,
Message Type 0x07
Detect ACC
accdet
Setup Low Power Alert
aepower
Send low power alert if power supply voltage is lower than specified value
send_sms: Duplicate alert over SMS
threshold: Threshold power value
Enable/Disable Antitheft (ACC ON) Alert
antitheft
enable: Enable Antitheft alert
backend_server2
Enable Connection to 2 Target Hosts
bothip
enable: Enable 2 IP work together
Enable/Disable BT
bt
enable_bt: Enable BT
Communication Mode Setup
dmode
report_mode: Report mode
Setup Drag alert
drag
time: Vibration detection time
towing_distance: Send alert after specified number of meters moved
Setup Heartbeat Interval
hbt
Turn LED on/off
ledon
led: Turn on LED
Set the device odometer value
mileagec
odometer: Odometer value
Control Network Modem and GPS Modem Sleep Mode
sleepmode
Control network modem and GPS modem status when ACC OFF and no vibration (when sleep network still keep alive with server)
mode: Sleepmode: when acc off and no vibration
Speed Limit for Overspeeding Event
speed
Setup Report Workmode
timer
distance: Distance
acc_on_period: ACC ON period
Setup Vibration Alert
vibration
Vibration alert will be raised if the following conditions are met: 1. ACC is OFF for "inactive state period" seconds 2. Vibration detected for "motion period" seconds 3. ACC is still OFF for "later period" seconds
later_period: ACC still OFF after vibration period
motion_period: ACC OFF period
inactive_period: Inactive state period
vibration_sensitivity: Vibration sensitivity
Get device IP2 setting
{"payload":"IP2,2#"}
{"payload":"DMODE,2#"}
