Topflytech TLP1-SM
Topflytech TLP1-SM is a 4G LTE asset GPS tracker with solar panel charging. The device features AGPS support, MQTT support, motion-controlled operations, 4800mAh rechargeable Li-Pol battery, FOTA, 2 parallel IPs support, SOS button, waterproof IP68 casing, built-in light & temperature sensor, a built-in magnet for mounting, USB & solar charging, and more. Suitable for 4G LTE Cat M1 / NB-IoT / EGPRS networks.
Parameters (107)
Settings (9)
Topflytech TLP1-SM
Flespi parses telemetry data from your Topflytech TLP1-SM into a standardized JSON and lets you send commands to Topflytech TLP1-SM via API.
    "device.type.id": "Topflytech TLP1-SM",
    "protocol.id": "topflytech"
How to send commands to Topflytech TLP1-SM?
accident.event
Accident event detected
Message Type 0x07
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Alarm Code 3,
Alarm Type 3,
Message Type 0x10,
Message Type 0x12
alarm.time
Message Type 0x13,
Message Type 0x14
Alarm Type 10
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Alarm Code 6,
Alarm Code 7,
Alarm Type 2,
Alarm Type 24
Message Type 0x02,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Message Type 0x10,
Message Type 0x12
ble.sensors
Message Type 0x10,
Message Type 0x12
Alarm Code 23,
Alarm Code 4
Message Type 0x09
Message Type 0x09
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04
Message Type 0x02,
Message Type 0x04
Message Type 0x13,
Message Type 0x14
case.status
Case opened status
Alarm Code 2,
Alarm Code 22
crash.status
Alarm Code 10,
Alarm Code 27
Message Type 0x02,
Message Type 0x13,
Message Type 0x14
Alarm Code 25,
Alarm Code 8
device.temperature.low.status
Alarm Code 30,
Alarm Code 31
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
displacement.status
Alarm Code 1,
Alarm Code 21
Message Type 0x13
Message Type 0x10,
Message Type 0x12
Message Type 0x02,
Message Type 0x13,
Message Type 0x14
Alarm Code 16,
Alarm Code 17,
Bit14 of Digital I/O status,
Bit2 of Status,
Message Type 0x02,
Message Type 0x04,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x21,
Message Type 0x23,
Message Type 0x24
Message Type 0x13,
Message Type 0x14
Message Type 0x09
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Alarm Type 1,
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14
Alarm Code 24,
Alarm Code 5
Message Type 0x02,
Message Type 0x04
Alarm Code 14,
Alarm Code 15,
Alarm Type 5,
Alarm Type 6
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
gsm.earfcn
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Alarm Type 21,
Alarm Type 22
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
gsm.network.name
Message Type 0x05,
Message Type 0x11
gsm.pcid
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Message Type 0x05,
Message Type 0x11
Message Type 0x05,
Message Type 0x11
Message Type 0x05,
Message Type 0x06
Message Type 0x05,
Message Type 0x06
Message Type 0x06
Alarm Code 18,
Alarm Code 19,
Alarm Type 19,
Alarm Type 20
light.sensor.voltage
Front light sensor voltage
Message Type 0x02,
Message Type 0x24
lock.data
Lock data in HEX format
Message Type 0x17
lock.state
Message Type 0x17
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17
movement.distance
Message Type 0x13
Alarm Type 8
Message Type 0x02,
Message Type 0x24
onewire.payload.hex
Message Type 0x23
Message Type 0x23
Alarm Type 4,
Message Type 0x05
Message Type 0x81
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x13,
Message Type 0x14
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x10,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x17,
Message Type 0x24
Alarm Code 20,
Alarm Code 29
Message Type 0x21
Message Type 0x21
solar.panel.charging.status
Solar panel charging device
Message Type 0x02,
Message Type 0x24
Message Type 0x02,
Message Type 0x24
tilt.status
Alarm Code 11,
Alarm Code 28
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x17,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24
time.valid.status
Time is accurate
Message Type 0x02,
Message Type 0x04,
Message Type 0x05,
Message Type 0x06,
Message Type 0x07,
Message Type 0x09,
Message Type 0x10,
Message Type 0x11,
Message Type 0x12,
Message Type 0x13,
Message Type 0x14,
Message Type 0x15,
Message Type 0x17,
Message Type 0x21,
Message Type 0x22,
Message Type 0x23,
Message Type 0x24
Alarm Type 7
usb.connection.status
Alarm Code 12,
Alarm Code 13
Message Type 0x02,
Message Type 0x04,
Message Type 0x13,
Message Type 0x14,
Message Type 0x24
Message Type 0x09,
Message Type 0x22
vibration.status
Alarm Code 26,
Alarm Code 9
Message Type 0x15,
Message Type 0x24
Message Type 0x15,
Message Type 0x24
Message Type 0x02,
Message Type 0x06,
Message Type 0x07
Message Type 0x02,
Message Type 0x06,
Message Type 0x07
Message Type 0x02,
Message Type 0x06,
Message Type 0x07
Detect ACC
accdet
backend_server2
Communication Mode Setup
dmode
report_mode: Report mode
Setup Heartbeat Interval
hbt
Set the device odometer value
mileagec
odometer: Odometer value
Setup Report Workmode
timer
distance: Distance
acc_on_period: ACC ON period
Get device IP2 setting
{"payload":"IP2,2#"}
{"payload":"DMODE,2#"}
