whereQube OBD 87
whereQube OBD 87 is a 4G GPS tracking device with CAN and Bluetooth. The device features an accelerometer, internal antenna, J1939, CAN, OBD II, driver behavior detection, buzzer alarm, HyperGPS technology for improved GPS performance, 300mAh Li-Ion battery, and more.
Parameters (131)
Settings (5)
whereQube OBD 87
Flespi parses telemetry data from your whereQube OBD 87 into a standardized JSON and lets you send commands to whereQube OBD 87 via API.
    "device.type.id": "whereQube OBD 87",
    "protocol.id": "geometris"
How to send commands to whereQube OBD 87?
ack.status
If message requires ACK from server
bluetooth.mode
Bluetooth mode
board.type
Board type
can.active.dtc
Active (stored) diagnostic trouble code read from CAN
can.active.dtc.mil.status
Malfunction indicator lamp status read from CAN together with active (stored) diagnostic trouble codes
can.active.dtc.number
Number of active (stored) diagnostic trouble codes
can.adblue.temperature
can.cumulative.fuel.economy
Cumulative fuel economy calculated for vehicle read from CAN
can.dm1.dtc
DM1 diagnostic trouble code read from CAN J1939
can.dm1.dtc.number
Number of DM1 diagnostic trouble codes for CAN J1939
can.dm1.mil.status
Malfunction indicator lamp status of DM1 for CAN J1939
can.dm2.dtc
DM2 diagnostic trouble code read from CAN J1939
can.dm2.dtc.number
Number of DM2 diagnostic trouble codes for CAN J1939
can.dm2.mil.status
Malfunction indicator lamp status of DM2 for CAN J1939
can.dpf.regeneration.threshold
DPF soot load regenration threshold read from CAN
can.dpf.regeneration.time
Time since last active regeneration of DPF read from CAN
can.dpf.soot.load
DPF soot load read from CAN
can.transmission.oil.level
can.transmission.oil.temerature
Volume of liquid fuel consumed for current trip read from CAN
Fuel economy calculated for current trip read from CAN
can.trip.gas.consumed
Mass of gas used by gaseous engine for current trip read from CAN
fault.tire
Axle and index of fault tire
fault.tire.cross.axle.fault.status
Fault tire cross axle fault
fault.tire.error.status
Fault tire status error
fault.tire.extreme.overpressure.status
Extreme overpressure of fault tire
fault.tire.extreme.underpressure.status
Extreme underpressure of fault tire
fault.tire.leakage.psi
Fault tire leakage rate
fault.tire.leak.status
Fault tire leak detected
fault.tire.low.status
Low TPMS battery on fault tire
fault.tire.overpressure.status
Fault tire overpressure
fault.tire.pressure.error.status
Pressure sensor error on fault tire
fault.tire.pressure.psi
Fault tire pressure
fault.tire.temperature
Fault tire temperature
fault.tire.temperature.error.status
Temperature sensor error on fault tire
fault.tire.underpressure.status
Fault tire underpressure
fault.tire.we.error.status
Wheel end sensor error on fault tire
firmware.hash
Firmware hash
firmware.type
Firmware type
gsm.msisdn
Mobile network (GSM, 3G, 4G, LTE, 5G, ...) station integrated services digital network number
gsm.sim.type
SIM type
hardware.options
Hardware options
rhumb
Heading in N,S,E,W notation
supervisor.version
Supervisor version
tire
Axle and tire index
Tire cross axle fault
tire.error.status
Tire status error
Extreme tire overpressure
Extreme tire underpressure
tire.leakage.psi
Tire leakage rate
tire.leak.status
Tire leak detected
tire.low.status
Low TPMS battery on tire
Tire overpressure
Pressure sensor error on tire
Temperature sensor error on tire
Tire underpressure
Wheel end sensor error on tire
total.idle.seconds
Network APN configuration
Packet Format
packet_format
Data packet assembly format. Overrides the default report format that is specified in the channel configuration.
config: Packet Format
Clear Queue
purge_queue
This command causes the device to remove all packets stored in the packet queue waiting to be transmitted to the server.
Reset
Perform soft reset of the device
Server
Backend server configuration
mode: Transmission Mode
payload: Text of command to be sent to the device
