AOVX EB100
AOVX EB100 is a tag with multiple sensors: temperature, humidity, light and motion sensors, which can monitor the conditions around the goods. The device features Bluetooth 4.2, replaceable 2 x 1.5V 1200mAh lithium and iron disulfide battery, 2.5 years battery life with default settings, and more.
Parameters (64)
Settings (13)
AOVX EB100
Flespi parses telemetry data from your AOVX EB100 into a standardized JSON and lets you send commands to AOVX EB100 via API.
    "device.type.id": "AOVX EB100",
    "protocol.id": "aovx"
How to send commands to AOVX EB100?
battery.charging.state
ble.sensors
data.type.enum
Data type code
Message ID
gpio.input
GPIO Input channel
gpio.output
GPIO Output channel
sensor.humidity.limit.max
Humidity sensor limit (max)
sensor.humidity.limit.min
Humidity sensor limit (min)
sensor.illuminance.limit.max
sensor.temperature.limit.max
sensor.temperature.limit.min
work.mode
Protocol-specific work mode
APN configuration
password: APN password
username: APN username
Bluetooth configuration
timeout: Nodes Timeout
max_nodes: Max Nodes
scan_time: Single scan time
work_mode: Work Mode
report_mask: Report Mask
Device configuration
device
timezone: Timezone
identifier: Device ID
Device information
Device information
iccid: ICCID
device_model: Device Model
factory
GNSS configuration
gnss
Heartbeat interval
heartbeat_interval
Set heartbeat interval
interval: Heartbeat interval
NTP configuration
ntp
NTP configuration
port: NTP server port
server: NTP server address
OTA upgrade
ota_upgrade
params: OTA params
Report configuration
report
Device restart
restart
Server
Server configuration
ack: Server ACK Enable
protocol: Protocol Type
WiFi configuration
wifi
WiFi configuration
max_ap: Max AP
