AOVX GM100
AOVX GM100 is an asset tracker with GPS, Beidou Wi-Fi, and other positioning technologies. The device features LTE Cat. M1/NB-IoT connectivity, BLE 5.0, temperature and humidity monitoring, low power alarm, unpacking alarm lamp, geofencing, and more.
Parameters (64)
Settings (16)
AOVX GM100
Flespi parses telemetry data from your AOVX GM100 into a standardized JSON and lets you send commands to AOVX GM100 via API.
    "device.type.id": "AOVX GM100",
    "protocol.id": "aovx"
How to send commands to AOVX GM100?
battery.charging.state
ble.sensors
data.type.enum
Data type code
Message ID
gpio.input
GPIO Input channel
gpio.output
GPIO Output channel
sensor.humidity.limit.max
Humidity sensor limit (max)
sensor.humidity.limit.min
Humidity sensor limit (min)
sensor.illuminance.limit.max
sensor.temperature.limit.max
sensor.temperature.limit.min
work.mode
Protocol-specific work mode
APN configuration
password: APN password
username: APN username
Bluetooth configuration
timeout: Nodes Timeout
max_nodes: Max Nodes
scan_time: Single scan time
work_mode: Work Mode
report_mask: Report Mask
Device configuration
device
timezone: Timezone
identifier: Device ID
Device information
Device information
iccid: ICCID
device_model: Device Model
factory
GNSS configuration
gnss
G-Sensor configuration
g_sensor
time: G-sensor time
range: Range
times: G-sensor times
trigger: G-sensor trigger interval,
sensitivity: Sensitivity
Heartbeat interval
heartbeat_interval
Set heartbeat interval
interval: Heartbeat interval
Light sensor configuration
light_sensor
trigger_interval: Trigger interval
NTP configuration
ntp
NTP configuration
port: NTP server port
server: NTP server address
OTA upgrade
ota_upgrade
params: OTA params
Report configuration
report
Device restart
restart
Server
Server configuration
ack: Server ACK Enable
protocol: Protocol Type
Temperature & humidity sensor configuration
temp_humi
humi_lower_limit: Lower Humidity Limit
humi_upper_limit: Upper Humidity Limit
temp_lower_limit: Lower Temperature Limit
temp_upper_limit: Upper Temperature Limit
WiFi configuration
wifi
WiFi configuration
max_ap: Max AP
