Avema AT35
Avema AT35 is an advanced GPS/GLONASS vehicle tracker with 4G LTE Cat 1 support. The device features built-in NFC support, HOS (Hours of Service) / ELD (Electronic Logging Device), geofencing, 10 self-defined events, configurable power management, RS232 interface, speeding alert, towing alert, low power alert, harsh braking alert, harsh acceleration alert, FOTA, built-in buzzer, Quick Develop Interface (QDI), support of 1-Wire interface temperature function and i-Button driver ID, low power consumption, and more.
Parameters (31)
Settings (8)
Avema AT35
Flespi parses telemetry data from your Avema AT35 into a standardized JSON and lets you send commands to Avema AT35 via API.
    "device.type.id": "Avema AT35",
    "protocol.id": "avema"
How to send commands to Avema AT35?
Device IMEI
device_imei
Firmware Version
firmware_version
version: Firmware Version
Harsh break alert function
hash_break_alert
Set harsh break alert function
hb_speed: HBSpeed
hb_duration: HBDuration
Idle condition
idle_condition
Set idle condition
idle_duration: Idle Duration
moving_duration: Moving Duration
Input port
input_port
Set Input port
in1_delay: Input 1 delay time
in2_delay: Input 2 delay time
in3_delay: Input 3 delay time
Device logging function
logging
Set device logging function
time: Time
times: Times
heading: Heading
distance: Distance
neglect_gps: NeglectGPS
Device communication method
server_communication
Set device communication method
type: Communication type
dns_ip: DNS IP
roaming: Enable Roaming
sync_pos: SyncPOS
username: UserName
server_ip: Server Host or IP
server_port: Server Port
sms_destination: SMS Destination
VIP phone numbers
vip_phones
VIP phone numbers for user defined reports
phone1: Phone 1
phone2: Phone 2
phone3: Phone 3
phone4: Phone 4
phone5: Phone 5
Reboot Device Unit
{"text":"$AVM,BOOT,[Password]"}
Get Device Firmware version
{"text":"$AVM,VER,[Password],?"}
Get Device System Information
{"text":"$AVM,INFO,[Password],?"}
