Avema MT99
Avema MT99 is a fully-featured, cost effective tracker with waterproof casing. The device features small size, robust design, IP67 compliance, smart power management, GPS & GSM jamming detection, geofencing, 10 self-defined events, speeding alert, towing alert, low power alert, harsh braking alert, harsh acceleration alert, FOTA, optional 800 mAh backup battery, optional Bluetooth 4.0 BLE support, and more.
Parameters (31)
Settings (8)
Avema MT99
Flespi parses telemetry data from your Avema MT99 into a standardized JSON and lets you send commands to Avema MT99 via API.
    "device.type.id": "Avema MT99",
    "protocol.id": "avema"
How to send commands to Avema MT99?
Device IMEI
device_imei
Firmware Version
firmware_version
version: Firmware Version
Harsh break alert function
hash_break_alert
Set harsh break alert function
hb_speed: HBSpeed
hb_duration: HBDuration
Idle condition
idle_condition
Set idle condition
idle_duration: Idle Duration
moving_duration: Moving Duration
Input port
input_port
Set Input port
in1_delay: Input 1 delay time
in2_delay: Input 2 delay time
in3_delay: Input 3 delay time
Device logging function
logging
Set device logging function
time: Time
times: Times
heading: Heading
distance: Distance
neglect_gps: NeglectGPS
Device communication method
server_communication
Set device communication method
type: Communication type
dns_ip: DNS IP
roaming: Enable Roaming
sync_pos: SyncPOS
username: UserName
server_ip: Server Host or IP
server_port: Server Port
sms_destination: SMS Destination
VIP phone numbers
vip_phones
VIP phone numbers for user defined reports
phone1: Phone 1
phone2: Phone 2
phone3: Phone 3
phone4: Phone 4
phone5: Phone 5
Reboot Device Unit
{"text":"$AVM,BOOT,[Password]"}
Get Device Firmware version
{"text":"$AVM,VER,[Password],?"}
Get Device System Information
{"text":"$AVM,INFO,[Password],?"}
