Eview EV-206M
Eview EV-206M is a 4G pet collar GPS tracker weighing only 19 grams. The device features 4G LTE-M/NB connectivity, activity monitoring, geofencing alert, no motion alert, IPX8 waterproof casing, KatchU app, and more.
Parameters (100)
Settings (61)
Eview EV-206M
Flespi parses telemetry data from your Eview EV-206M into a standardized JSON and lets you send commands to Eview EV-206M via API.
    "device.type.id": "Eview EV-206M",
    "protocol.id": "eview"
How to send commands to Eview EV-206M?
agps.position.valid
AGPS data valid
Command 0x01 with Key 0x24,
Command 0x03 with Key 0x24
alarm.panic.start
Panic alarm event started
Command 0x01 with Key 0x02
alarm.panic.stop
Panic alarm event ended
amber.alarm.start
Amber alarm event started
amber.alarm.stop
Amber alarm event stopped
Command 0x01 with Key 0x02,
battery.full
Battery fully charged
Command 0x02 with Key 0x14,
beacon.absence.status
Beacon absence alarm status
beacon.come.home.alarm
Beacon come home alert
beacon.leave.home.alarm
Beacon leave home alert
Command 0x01 with Key 0x28,
Command 0x01 with Key 0x2C
ble.disconnected.alarm
BLE disconnected alert
Command 0x01 with Key 0x23,
Command 0x01 with Key 0x26
call.duration
Call duration
Command 0x01 with Key 0x25
call.return.code
Call return code
call.status
Call status bit
call.type
Call type
call.type.enum
Call type number
Command 0x03 with Key 0x30
device.reboot
Device reboot status
Command 0x02 with Key 0x13
Command 0x01 with Key 0x03
Command 0x01
fall.alarm.start
Fall alarm event started
fall.alarm.status
Fall alarm status
fall.alarm.stop
Fall alarm event stopped
Command 0x01 with Key 0x20
Command 0x01 with Key 0x21,
Command 0x01 with Key 0x29,
Command 0x01 with Key 0x2B,
Command 0x03 with Key 0x21
Command 0x01 with Key 0x04
heart.rate
bpm
Heart rate
Command 0x01 with Key 0x40
heart.rate.trust.level
Heart rate trust level
indoor.status
Indoor status flag
location.source.beacon
Location is obtained by Beacon
location.source.bluetooth
Location is obtained by Bluetooth
location.source.gps
Location is obtained via GPS
location.source.gsm
Location is obtained by Mobile network (GSM, 3G, 4G, LTE, 5G, ...) cell towers
location.source.smart
Smart locating flag
location.source.wifi
Location is obtained by Wi-Fi
no.motion.alarm
No motion alarm
one.day.upload
One day upload alarm flag
pet.activity
Pet activity
Command 0x01 with Key 0x31
position.address
Location Address
Command 0x01 with Key 0x2A
Command 0x01 with Key 0x20,
Command 0x01 with Key 0x26,
Command 0x01 with Key 0x27
Command 0x01 with Key 0x27,
side.call.button
Side call button alarm
spo2.rate
SPO2 rate
Command 0x01 with Key 0x41
spo2.rate.trust.level
SPO2 rate trust level
startup.alarm
Startup alarm event
Command 0x01 with Key 0x30
tilt.status
Command 0x01 with Key 0x19,
Command 0x01 with Key 0x25,
Command 0x01 with Key 0x2A,
Command 0x01 with Key 0x30,
Command 0x01 with Key 0x31,
Command 0x01 with Key 0x40,
Command 0x01 with Key 0x41,
welfare.alarm.start
Welfare alarm event started
welfare.alarm.stop
Welfare alarm event stopped
wifi.home.status
Home Wi-Fi location flag
Command 0x01 with Key 0x22,
wifi.status
Wifi connection status
Alarm Clock 1
alarm_clock1
hour: Hour
friday: Friday
minute: Minute
monday: Monday
sunday: Sunday
tuesday: Tuesday
duration: Alarm reminder duration
ringtone: Ringtone number
saturday: Saturday
thursday: Thursday
wednesday: Wednesday
Alarm Clock 2
alarm_clock2
hour: Hour
friday: Friday
minute: Minute
monday: Monday
sunday: Sunday
tuesday: Tuesday
saturday: Saturday
thursday: Thursday
Alarm Clock 3
alarm_clock3
hour: Hour
friday: Friday
minute: Minute
monday: Monday
sunday: Sunday
tuesday: Tuesday
saturday: Saturday
thursday: Thursday
Alarm Clock 4
alarm_clock4
hour: Hour
friday: Friday
minute: Minute
monday: Monday
sunday: Sunday
tuesday: Tuesday
saturday: Saturday
thursday: Thursday
SMS to set APN
apn_sms
Request Device Battery State
battery
Configuration
configuration
Readonly setting to check device firmware and hardware info
iccid: ICCID
ble_mac: BLE MAC
runtime: Runtime in seconds
timestamp: Timestamp
module_number: Module number
Enable Control
enable_control
Enable Control of eview protocol
led: Enable LED
agps: Enable AGPS
beep: Enable Beep
wi_fi: Enable Wi-Fi
activity: Enable Activity function
long_sms: Enable Long SMS
alert_tcp: Enable TCP fast
home_wifi: Enable Home WI-FI location
vibration: Enable Vibration
data_saver: Enable Data saver
sos_cancel: Enable SOS cancellation switch
step_count: Enable Step counting function
auto_update: Enable Auto update
power_cntrl: Enable Power control
raise_wrist: Enable Raise wrist to awake
ble_locating: Enable Bluetooth locating
gps_locating: Enable GPS locating
net_location: Enable Network location provider
ble_always_on: Enable Bluetooth always on
sos_call_voice: Enable SOS Call Voice
home_beacon_loc: Enable Home beacon location
sos_call_speaker: Enable SOS call speaker
side_call_speaker: Enable Side call speaker
ble_stay_connected: Enable Bluetooth stay connected
cell_tower_locating: Enable Cell tower locating
Fall Down Alert
fall_down_alert
dial: Dial
always_on: Always ON
sensitive_level: Sensitive level
Find Me
find_me
Looking for equipment
Firmware upgrade
firmware_upgrade2
dat_file_uuid: CDN .dat File UUID
encyped_file_uuid: CDN .encrypted File UUID
Firmware Info
fw_info
Readonly setting to check Firmware info details
sd_fwid: Soft-device FWID
version: version
hw_version: HW version
sd_version: Soft-device version
compiler_date: Firmware compiler date
compiler_time: Firmware compiler time
GEO Alert 1
geo_alert1
GEO Alert setting works with Circle type yet. To add polygon geozone type - contact flespi support
radius: Radius
latitude: Latitude
direction: Direction
longitude: Longitude
GEO Alert 2
geo_alert2
radius: Radius
latitude: Latitude
GEO Alert 3
geo_alert3
radius: Radius
latitude: Latitude
GEO Alert 4
geo_alert4
radius: Radius
latitude: Latitude
Continue Locate Time Parameter
locate_time
time: Time
Microphone volume
microphone_volume
level: Microphone level
Motion Alert
motion_alert
dial: Dial
moving_period: Continued moving period to activate the alert.
cooldown_period: Cooldown period
No Disturb
no_disturb
end_hour: End hour
end_minute: End minute
start_hour: Start hour
start_minute: Start minute
No-Motion Alert
no_motion_alert
dial: Dial
static_period: Continued static period to activate the alert
Over Speed Alert
over_speed_alert
threshold: Over speed threshold
Password Protect
password_protect
Phone Number 1
phone1
Authorized phone number 1
number: Phone number
accept_sms: Accept SMS
no_sim_dialing: No SIM dialing
accept_phone_call: Accept Phone Call
Phone Number 10
phone10
Authorized phone number 10
Phone Number 2
phone2
Authorized phone number 2
Phone Number 3
phone3
Authorized phone number 3
Phone Number 4
phone4
Authorized phone number 4
Phone Number 5
phone5
Authorized phone number 5
Phone Number 6
phone6
Authorized phone number 6
Phone Number 7
phone7
Authorized phone number 7
Phone Number 8
phone8
Authorized phone number 8
Phone Number 9
phone9
Authorized phone number 9
Phone Switches
phone_switches
sos_phone_enable: SOS phone ring enable
auto_answer_enable: Auto answer enable
button_hangup_enable: Button hang up enable
sms_whitelist_enable: SMS whitelist enable
a1_phone_monitor_enable: A1 phone monitor enable
auto_answer_after_rings: Auto answer after rings
call_in_whitelist_enable: Enable Call In White List
Power Alert
power_alert
power_on: Alert Power ON
low_power: Low Power alert
power_off: Alert Power OFF
user_low_power: User Low Power alert
user_threshold: User Low Power alert Threshold
low_power_threshold: Low Power Alert Threshold
low_power_voice_prompt: Low Power Voice Prompt
voice_prompt_threshold: Low Power Voice Prompt Threshold
Power Off
power_off
Ringtone volume
ringtone_volume
level: Volume level
Server IP and Port
server_ip_port
protocol: Communication protocol
gprs_enable: GPRS Enable
SMS to set server IP and Port
server_ip_port_sms
enable: GPRS Enable
Single Locating
single_locating
This command is sent from server to the device to request the device to update the latest location data
SMS GPS URL
sms_gps_url
url: URL
SMS reply prefix
sms_prefix
txt: Text
Speaker volume
speaker_volume
level: Speaker level
Sync time
sync_time
System language
system_lang
code: Country code
Tilt Alert
tilt_alert
dial: Dial
time_threshold: Tilt Time threshold
angle_threshold: Tilt Angle threshold
Time Interval
time_interval
heartbeat: Heartbeat Enable
auto_upload_interval: Auto upload interval
auto_upload_lazy_interval: Auto upload lazy interval
Time zone
time_zone
time_zone: Time zone
Voice prompt volume
voice_prompt_volume
level: Level
WiFi 1 whitelist
wifi1
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 10 whitelist
wifi10
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 2 whitelist
wifi2
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 3 whitelist
wifi3
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 4 whitelist
wifi4
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 5 whitelist
wifi5
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 6 whitelist
wifi6
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 7 whitelist
wifi7
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 8 whitelist
wifi8
mac: MAC adress
ssid: WiFi name
latitude: Latitude
WiFi 9 whitelist
wifi9
mac: MAC adress
ssid: WiFi name
latitude: Latitude
Working Mode
working_mode
interval: Time/Interval
Send custom command via connection. Only message body is requred: header, properties, length and checksum are added automatically
Find Me command
{"hex":"040113"}
Reboot EV-07S device
{"text":"123456T"}
Device reboot command
{"hex":"040112"}
