Fifotrack A700
Fifotrack A700 is a versatile GPS tracker ideal for fleet, school bus, taxi, and vehicle insurance management. Equipped with 4 RS232 ports and 1-Wire protocol, it supports functionalities like picture taking, driver ID, temperature monitoring, fuel theft alerts, and two-way communication. It features a robust power system, ensuring no device burning issues. Its durable design makes it a lasting solution, especially for rental services. Dimensions are 90*60*27mm, weight 145g, and an internal battery life of up to 15 hours in sleep mode.
Parameters (58)
Fifotrack A700
Flespi parses telemetry data from your Fifotrack A700 into a standardized JSON and lets you send commands to Fifotrack A700 via API.
    "device.type.id": "Fifotrack A700",
    "protocol.id": "fifotrack"
How to send commands to Fifotrack A700?
fuel.theft.alarm
Fuel Theft Alarm
high.temperature.alarm
High temperature alarm
low.temperature.alarm
Low temperature alarm
overtime.parking.alarm
Over time Parking
vehicle.odometer
Set OUT1 to output high level when speed less than 20km/h
{"payload":"B12,1,1,20"}
