Fifotrack Q2
The Fifotrack Q2 is a contemporary portable GPS tracker ideal for monitoring kids, elders, employees, lone workers, pets, animals, and valuable assets. This device is well-balanced in terms of size and battery longevity, offering a working time of up to 15 days at a 24-hour tracking interval or up to 3 days at a 5-minute tracking interval, ensuring consistent monitoring over extended periods. It has earned the IP67 waterproof standard making it a fit for outdoor uses. One of the standout features is its two-way communication facilitated by an in-built microphone and speaker, enabling interactions between the user and a pre-set SOS phone guardian. Adding to its versatility is a WiFi function that provides an indoor tracking option. The device is powered by a 1000mAh lithium-ion battery and comes with a cradle for charging. Its built-in 6-axis motion sensor paired with an efficient firmware algorithm allows for the accurate detection of Tilt/Man down/Fall down events, enhancing its safety monitoring capabilities. This device operates on a 4G network and also offers a stable GPS/GSM signal for reliable tracking.
Parameters (58)
Fifotrack Q2
Flespi parses telemetry data from your Fifotrack Q2 into a standardized JSON and lets you send commands to Fifotrack Q2 via API.
    "device.type.id": "Fifotrack Q2",
    "protocol.id": "fifotrack"
How to send commands to Fifotrack Q2?
fuel.theft.alarm
Fuel Theft Alarm
high.temperature.alarm
High temperature alarm
low.temperature.alarm
Low temperature alarm
overtime.parking.alarm
Over time Parking
vehicle.odometer
Set OUT1 to output high level when speed less than 20km/h
{"payload":"B12,1,1,20"}
