Fifotrack Q3
The Fifotrack Q3 is a 4G+2G LTE personal GPS tracker tailored for diverse tracking needs including the elderly, children, employees, lone workers, pets, animals, and valuable assets. It achieves a harmony between compactness and battery longevity, providing up to 6.5 days of working time with a 10-minute tracking interval. The device is IP67 certified, making it suitable for outdoor usage. Notably, it supports two-way communication courtesy of its in-built microphone and speaker, allowing for interaction between the user and a preset SOS phone contact. The Q3 also has a fall detection feature powered by a built-in 3-axis motion sensor and a smart firmware algorithm. Other highlights include a stable GPS/GSM signal, a built-in 1000mAh lithium-ion battery, WiFi tracking option, no movement alarm, and charging via a cradle, ensuring it remains a reliable tracking companion in various scenarios.
Parameters (58)
Fifotrack Q3
Flespi parses telemetry data from your Fifotrack Q3 into a standardized JSON and lets you send commands to Fifotrack Q3 via API.
    "device.type.id": "Fifotrack Q3",
    "protocol.id": "fifotrack"
How to send commands to Fifotrack Q3?
fuel.theft.alarm
Fuel Theft Alarm
high.temperature.alarm
High temperature alarm
low.temperature.alarm
Low temperature alarm
overtime.parking.alarm
Over time Parking
vehicle.odometer
Set OUT1 to output high level when speed less than 20km/h
{"payload":"B12,1,1,20"}
