Streamax X3-H0402
Streamax X3-H0402 is an MDVR for vehicle video surveillance and remote monitoring. The device features a high-speed processor and embedded operating system combined with the most advanced H.264 video compression/decompression technology, network, as well as GPS positioning technology. It supports not only video recording in 720P, WD1, HD1, and CIF formats, but also vehicle travel information recording and wireless data upload. The device collects rich location-related information.
Important: flespi currently only parses the location data coming from the device but does not process or store the video stream.
Parameters (116)
Settings (4)
Streamax X3-H0402
Flespi parses telemetry data from your Streamax X3-H0402 into a standardized JSON and lets you send commands to Streamax X3-H0402 via API.
    "device.type.id": "Streamax X3-H0402",
    "protocol.id": "streamax"
How to send commands to Streamax X3-H0402?
accelerometer.alarm.enum
accelerometer.alarm.event
Accelerometer alarm event
OPERATION UPDATEIOSTATUS
alarm.subtype
Alarm sub-type
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
can.hydraulics.pressure
CSRC 2
can.left.steering.status
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CAN brake pedal pressed
CSRC 2
CSRC 2
CSRC 2
can.right.steering.status
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
OPERATION SPI
driver.alarm.type
CSRC 2
OPERATION UPLOADMDVRDRVINFO
driver.physical.card.id
Driver physical card number
CSRC 2
drum.direction
Drum direction
CSRC 2
drum.rotation.speed
Drum rotation speed
CSRC 2
CSRC 2,
OPERATION SPI,
event.uuid
Event UUID
expanded.data
CSRC 2
CSRC 2
CSRC 2
OPERATION SPI
OPERATION SPI
io.enable.bitmask
CSRC 2
io.level.bitmask
CSRC 2
io.mode.bitmask
CSRC 2
io.state.bitmask
CSRC 2
CSRC 2
message.detail
Message detail
network.type
Network connection type
OPERATION UPDATENETTYPE
operation.errorcause
Operation ERRORCAUSE
OPERATION UPTIMESHIFTRES,
OPERATION UPUPGRADESTATUS
operation.errorcode
Operation ERRORCODE
CSRC 2
CSRC 2,
OPERATION SENDALARMINFO,
OPERATION SPI,
CSRC 2
CSRC 2,
OPERATION SPI,
CSRC 2,
OPERATION SPI,
CSRC 2
CSRC 2,
OPERATION SPI,
OPERATION SPI,
CSRC 2,
OPERATION SPI,
CSRC 2
storage.error.code
Storage error code
storage.id
Storage index
storage.type.id
Storage type enum id
CSRC 2,
CSRC 2,
OPERATION SPI
video.channel.bitmask
video.loss.event
Video loss alarm event
wash.status
Wash I/O status
CSRC 2
water.value
Water added value
CSRC 2
wifi.module.status
Wi-Fi module status
OPERATION SPI
wifi.signal.level
WiFi signal level, percentage
OPERATION SPI
CSRC 2
x.acceleration.angle
X axis angle data
CSRC 2
CSRC 2
y.acceleration.angle
Y axis angle data
CSRC 2
CSRC 2
z.acceleration.angle
Z axis angle data
CSRC 2
iccid: ICCID
device_model: Device Model
customer_name: Customer Name
Position state parameters
position_state_parameters
num: Upload frequency ranging
time: Time interval
enable: Realtime monitoring
distance: Distance interval
Reboot device
timezone
Time Zone Setup
z: Time Zone
Custom
directive
module: MODULE field
operation: OPERATION field
parameter: PARAMETER field
quality: Quality
resolution: Resolution
