Streamax X3N-H0404
Streamax X3N-H0404 is a cost-effective mobile digital video recorder designed for video surveillance and monitoring with high scalability. It includes a high-speed processor, H.265 video technology, 3G/4G, GPS, Wi-Fi, various recording formats, remote video upload, and AI-enhanced functions.
Parameters (116)
Settings (4)
Streamax X3N-H0404
Flespi parses telemetry data from your Streamax X3N-H0404 into a standardized JSON and lets you send commands to Streamax X3N-H0404 via API.
    "device.type.id": "Streamax X3N-H0404",
    "protocol.id": "streamax"
How to send commands to Streamax X3N-H0404?
accelerometer.alarm.enum
accelerometer.alarm.event
Accelerometer alarm event
OPERATION UPDATEIOSTATUS
alarm.subtype
Alarm sub-type
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
can.hydraulics.pressure
CSRC 2
can.left.steering.status
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CAN brake pedal pressed
CSRC 2
CSRC 2
CSRC 2
can.right.steering.status
CSRC 2
CSRC 2
CSRC 2
CSRC 2
CSRC 2
OPERATION SPI
driver.alarm.type
CSRC 2
OPERATION UPLOADMDVRDRVINFO
driver.physical.card.id
Driver physical card number
CSRC 2
drum.direction
Drum direction
CSRC 2
drum.rotation.speed
Drum rotation speed
CSRC 2
CSRC 2,
OPERATION SPI,
event.uuid
Event UUID
expanded.data
CSRC 2
CSRC 2
CSRC 2
OPERATION SPI
OPERATION SPI
io.enable.bitmask
CSRC 2
io.level.bitmask
CSRC 2
io.mode.bitmask
CSRC 2
io.state.bitmask
CSRC 2
CSRC 2
message.detail
Message detail
network.type
Network connection type
OPERATION UPDATENETTYPE
operation.errorcause
Operation ERRORCAUSE
OPERATION UPTIMESHIFTRES,
OPERATION UPUPGRADESTATUS
operation.errorcode
Operation ERRORCODE
CSRC 2
CSRC 2,
OPERATION SENDALARMINFO,
OPERATION SPI,
CSRC 2
CSRC 2,
OPERATION SPI,
CSRC 2,
OPERATION SPI,
CSRC 2
CSRC 2,
OPERATION SPI,
OPERATION SPI,
CSRC 2,
OPERATION SPI,
CSRC 2
storage.error.code
Storage error code
storage.id
Storage index
storage.type.id
Storage type enum id
CSRC 2,
CSRC 2,
OPERATION SPI
video.channel.bitmask
video.loss.event
Video loss alarm event
wash.status
Wash I/O status
CSRC 2
water.value
Water added value
CSRC 2
wifi.module.status
Wi-Fi module status
OPERATION SPI
wifi.signal.level
WiFi signal level, percentage
OPERATION SPI
CSRC 2
x.acceleration.angle
X axis angle data
CSRC 2
CSRC 2
y.acceleration.angle
Y axis angle data
CSRC 2
CSRC 2
z.acceleration.angle
Z axis angle data
CSRC 2
iccid: ICCID
device_model: Device Model
customer_name: Customer Name
Position state parameters
position_state_parameters
num: Upload frequency ranging
time: Time interval
enable: Realtime monitoring
distance: Distance interval
Reboot device
timezone
Time Zone Setup
z: Time Zone
Custom
directive
module: MODULE field
operation: OPERATION field
parameter: PARAMETER field
quality: Quality
resolution: Resolution
