Teltonika FM1100
Teltonika FM1100 is light terminal with GPS/GLONASS and GSM connectivity, which is able to get device coordinates and other data and transfer them via GSM network. This device is perfectly suitable for tracking remote objects (trucks, cars etc) quickly and easily.
Parameters (731)
Settings (9)
Teltonika FM1100
Flespi parses telemetry data from your Teltonika FM1100 into a standardized JSON and lets you send commands to Teltonika FM1100 via API.
    "device.type.id": "Teltonika FM1100",
How to send commands to Teltonika FM1100?
AVL ID 9...10
s
AVL ID 713...716,
AVL ID 729...744
AVL ID 29
AVL ID 10820...10823
AVL ID 10808...10811
degree
AVL ID 10816...10819
degree
AVL ID 10832...10835
AVL ID 25...28
AVL ID 389
AVL ID 389
percantage
AVL ID 10445,
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
amps
amps
AVL ID 168
AVL ID 518
AVL ID 518
current
AVL ID 81
s
AVL ID 518
AVL ID 282
can.electric.engine.status
AVL ID 1035
AVL ID 235
celcius
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
s
Time to full from CAN bus
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
watts
amps
amps
AVL ID 388
AVL ID 518
CAN brake pedal pressed
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
amps
AVL ID 107
AVL ID 518
can.trip.engine.motorhours
AVL ID 102
amps
kW/h
kW/h
Webasto status read from CAN
custom.user.id
AVL ID 238,
AVL ID 4
AVL ID 842
AVL ID 88
AVL ID 10428...10431
AVL ID 641
Media type
AVL ID 20015
AVL ID 10611...10612
AVL ID 24
Tacho driver card presence
Tacho drive recognize
AVL ID 225
AVL ID 209
APN Name
gprs_apn_1profile
APN Password
gprs_apn_password_1profile
APN Username
gprs_apn_username_1profile
GPRS Content Activation
gprs_enable_1profile
enable: Enable GPRS
Digital Outputs
outputs2
out1: Output 1
out2: Output 2
Backend Server Host
server_host_1profile
Backend Server Port
server_port_1profile
Backend Server Protocol
server_protocol_1profile
protocol: Protocol
setdigout_2
{"text":"getrecord"}
