Teltonika FM3001
Teltonika FM3001 is an advanced plug-and-track GLONASS/GPS tracker with 2G/3G (Micro-SIM), Bluetooth, direct OBDII connectivity, crash detection, idling detection, and internal battery.
Parameters (731)
Settings (95)
Teltonika FM3001
Flespi parses telemetry data from your Teltonika FM3001 into a standardized JSON and lets you send commands to Teltonika FM3001 via API.
    "device.type.id": "Teltonika FM3001",
How to send commands to Teltonika FM3001?
AVL ID 9...10
s
AVL ID 713...716,
AVL ID 729...744
AVL ID 29
AVL ID 10820...10823
AVL ID 10808...10811
degree
AVL ID 10816...10819
degree
AVL ID 10832...10835
AVL ID 25...28
AVL ID 389
AVL ID 389
percantage
AVL ID 10445,
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
amps
amps
AVL ID 168
AVL ID 518
AVL ID 518
current
AVL ID 81
s
AVL ID 518
AVL ID 282
can.electric.engine.status
AVL ID 1035
AVL ID 235
celcius
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
s
Time to full from CAN bus
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
watts
amps
amps
AVL ID 388
AVL ID 518
CAN brake pedal pressed
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
amps
AVL ID 107
AVL ID 518
can.trip.engine.motorhours
AVL ID 102
amps
kW/h
kW/h
Webasto status read from CAN
custom.user.id
AVL ID 238,
AVL ID 4
AVL ID 842
AVL ID 88
AVL ID 10428...10431
AVL ID 641
Media type
AVL ID 20015
AVL ID 10611...10612
AVL ID 24
Tacho driver card presence
Tacho drive recognize
AVL ID 225
AVL ID 209
accelerometer_gravity
Authorized beacons list
auth_beacons
id1: BLE Beacon UID 1
id2: BLE Beacon UID 2
id3: BLE Beacon UID 3
id4: BLE Beacon UID 4
id5: BLE Beacon UID 5
id6: BLE Beacon UID 6
id7: BLE Beacon UID 7
id8: BLE Beacon UID 8
id9: BLE Beacon UID 9
id10: BLE Beacon UID 10
id11: BLE Beacon UID 11
id12: BLE Beacon UID 12
id13: BLE Beacon UID 13
id14: BLE Beacon UID 14
id15: BLE Beacon UID 15
id16: BLE Beacon UID 16
id17: BLE Beacon UID 17
id18: BLE Beacon UID 18
id19: BLE Beacon UID 19
id20: BLE Beacon UID 20
id21: BLE Beacon UID 21
id22: BLE Beacon UID 22
id23: BLE Beacon UID 23
id24: BLE Beacon UID 24
id25: BLE Beacon UID 25
Secondary GPRS Server Setup
backup_server
Battery charge mode
battery_chagrge_mode
Beacon settings
beacon
record: Beacon Records
detection: Beacon detection
BLE common settings
ble_common
Bluetooth work mode
local_name: Local name
security_mode: Security mode
bluetooth_auto_connect
mode: Connection mode
external_mac: External Mac
external_pin: External PIN
external_name: External name
Restart (reboot) the device
cpureset
data_codec
codec: Data codec
Firmware Over The Air web serivce
fota
web: Enable
getgps
Send getimeiccid command
getimeiccid
getrecord
GNSS Source
gnss_source
gps: GPS
beidou: Beidou
galileo: Galileo
glonass: Glonass
gprs
enabled: GPRS Enabled
GPRS Server Setup
gprs_server
protocol: Server protocol
Green Driving
green_driving_obd
sms: Send SMS
prio: Priority
source: Source
max_accel: Max Acceleration
max_angle: Max Angle
max_brake: Max Braking
Phone Numbers
gsm_numbers
Predefined GSM phone numbers
phone1: Phone Number 1
phone2: Phone Number 2
phone3: Phone Number 3
phone4: Phone Number 4
phone5: Phone Number 5
phone6: Phone Number 6
phone7: Phone Number 7
phone8: Phone Number 8
phone9: Phone Number 9
phone10: Phone Number 10
Excessive Idling Detection
idling_obd
sms: Send SMS
prio: Priority
record: Eventual Records
move_time: Move Timeout
stop_time: Stop Timeout
Ignition Detection Source
ignition_detection
ign: Ignition Source
Ignition ON counter
ignition_on_counter
counter_value: Counter value
Incoming call action
incoming_call
LED Indication
led_indication
enabled: Enabled
lvcanblockengine
lvcanclosealldoors
lvcanopenalldoors
lvcanopentrunk
lvcanturninglights
One flash of all turn lights ordered trough accidental / blinking turn light switch
lvcanunblockengine
lvcanwindowsclose
time: Closing time
lvcanwindowsopen
time: Opening time
Motion Detection Source
motion_detection
can: CAN Speed
gps: GPS
ignition: Ignition
movement: Movement sensor
Network Time Protocol server
ntp_server
ntp_server1: NTP Server 1
ntp_server2: NTP Server 2
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
sms_number: Phone Number
Absolute load value
obd_absolute_load_value_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Ambient air temperature
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Barometric pressure
obd_barometric_pressure_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Commanded EGR
obd_commanded_egr_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Command Equivalence Ratio
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Control module voltage
obd_control_module_voltage_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Coolant Temperature
obd_coolant_temperature_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Direct fuel rail pressure
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Distance traveled MIL on
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
EGR error
obd_egr_error_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Engine Load
obd_engine_load_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Engine oil temperature
obd_engine_oil_temperature_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Engine RPM
obd_engine_rpm_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Fault Codes
obd_fault_codes_io
prio: Priority
sms_text: SMS text
Fuel injection timing
obd_fuel_injection_timing_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Fuel level
obd_fuel_level_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Fuel Pressure
obd_fuel_pressure_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Fuel Rate
obd_fuel_rate_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Fuel Type
obd_fuel_type_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Hybrid Vehicle System Current
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Hybrid Vehicle System Voltage
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
obd_intake_air_temperature_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Intake MAP 2b
obd_intake_map_2b_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Intake Map
obd_intake_map_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
MAF
obd_maf_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Number Of DTC
obd_number_of_dtc_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
OEM Battery Charge Level
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
OEM Battery Charge State
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
OEM Fuel Level
obd_oem_fuel_level_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
OEM Remaining Distance
obd_oem_remaining_distance_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
OEM Total Mileage
obd_oem_total_mileage_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Relative fuel rail pressure
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Run time since engine start
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Short Fuel Trim
obd_short_fuel_trim_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Throttle position
obd_throttle_position_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Time run with MIL on
obd_time_run_with_mil_on_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Timing advance
obd_timing_advance_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
Vehicle speed
obd_vehicle_speed_io
low: Low Level
high: High Level
prio: Priority
sms_text: SMS text
VIN
obd_vin_io
prio: Priority
sms_text: SMS text
odometer_fmb
source: Calculation source
Tracking on demand mode
on_demand_mode
type: On demand tracking mode
Tracking on demand timing
on_demand_params
period: Tracking period
duration: Tracking duration
Overspeeding
overspeeding_obd
sms: Send SMS
prio: Priority
max_speed: Max Speed
order: Records Soring Order
Format SD card
sdformat
SMS report sending parameters
sms_reports
Static Navigation
static_filter
stat_nav: Static Navigation
SMS event Time Zone
timezone_sms
Enable connection over TLS
tls
enable: TLS enable
Trip scenario parameters
trip_scenario
sms: Send SMS
prio: Priority
start_speed: Start speed
Unknown GSM Network Settings
unknown_network
web_connect
{"text":"getrecord"}
