Teltonika FM1202
Teltonika FM1202 is a terminal with GPS and GSM connectivity, which is able to determine the object’s coordinates and transfer them via the GSM network. This device is perfectly suitable for applications, which need location detection of remote objects. It is important to mention that Teltonika FM1202 has additional inputs and outputs, which let you control and monitor other devices on remote objects. Teltonika FM1202 also has IP67 waterproof housing for use in wet conditions.
Parameters (731)
Settings (70)
Teltonika FM1202
Flespi parses telemetry data from your Teltonika FM1202 into a standardized JSON and lets you send commands to Teltonika FM1202 via API.
    "device.type.id": "Teltonika FM1202",
How to send commands to Teltonika FM1202?
AVL ID 9...10
s
AVL ID 713...716,
AVL ID 729...744
AVL ID 29
AVL ID 10820...10823
AVL ID 10808...10811
degree
AVL ID 10816...10819
degree
AVL ID 10832...10835
AVL ID 25...28
AVL ID 389
AVL ID 389
percantage
AVL ID 10445,
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
amps
amps
AVL ID 168
AVL ID 518
AVL ID 518
current
AVL ID 81
s
AVL ID 518
AVL ID 282
can.electric.engine.status
AVL ID 1035
AVL ID 235
celcius
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
s
Time to full from CAN bus
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
watts
amps
amps
AVL ID 388
AVL ID 518
CAN brake pedal pressed
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
amps
AVL ID 107
AVL ID 518
can.trip.engine.motorhours
AVL ID 102
amps
kW/h
kW/h
Webasto status read from CAN
custom.user.id
AVL ID 238,
AVL ID 4
AVL ID 842
AVL ID 88
AVL ID 10428...10431
AVL ID 641
Media type
AVL ID 20015
AVL ID 10611...10612
AVL ID 24
Tacho driver card presence
Tacho drive recognize
AVL ID 225
AVL ID 209
Active Data Link
active_link
Defines for how many seconds device will keep connection to the server after successful data transfer while waiting for a new record
Analog Input Range
ain_range
Analog input measuring resolution and range can be defined as 0 - 10V or 1 - 30V
range: Range
AIN SMS Event
ain_sms_event
Configure SMS event for AIN event
sms_text: SMS Text
sms_phone: Phone Number Index
DIN2
din2
Parameter defines DIN2 value
DIN2 Averaging Length
din2_averaging
Parameter defines DIN2 property sample length to average
value: Value
DIN2 High Level
din2_high
Parameter defines high value of triggered DIN2 property
value: Value
DIN2 Low Level
din2_low
Parameter defines low value of triggered DIN2 property
value: Value
DIN2 Operand
din2_operand
Parameter defines when DIN2 event is sent
value: Value
DIN2 Priority
din2_priority
Parameter defines DIN2 priority value
value: Priority
DIN2 SMS Event
din2_sms_event
Configure SMS event for DIN2 event
sms_text: SMS Text
DIN3/AIN
din3
Parameter defines DIN3/AIN value
value: Value
DIN3/AIN Averaging Length
din3_averaging
Parameter defines DIN3/AIN property sample length to average
value: Value
DIN3/AIN High Level
din3_high
Parameter defines high value of triggered DIN3/AIN property
value: Value
DIN3/AIN Low Level
din3_low
Parameter defines low value of triggered DIN3/AIN property
value: Value
DIN3/AIN Operand
din3_operand
Parameter defines when DIN3/AIN event is sent
value: Value
DIN3/AIN Priority
din3_priority
Parameter defines DIN3/AIN priority value
value: Priority
DIN3 SMS Event
din3_sms_event
Configure SMS event for DIN3 event
sms_text: SMS Text
APN Name
gprs_apn_1profile
APN Password
gprs_apn_password_1profile
APN Username
gprs_apn_username_1profile
GPRS Content Activation
gprs_enable_1profile
enable: Enable GPRS
Home Network: On Move: Min Angle
home_on_move_min_angle
This parameter indicates angle in degrees in order to acquire new record
min_angle: Min Angle
Home Network: On Move: Min Distance
home_on_move_min_distance
This parameter indicates distance in meters in order to acquire new record
min_distance: Min Distance
Home Network: On Move: Min Period
home_on_move_min_period
This parameter indicates time interval in seconds in order to acquire new record
min_period: Min Period
Home Network: On Move: Min Saved Records
home_on_move_min_records
This parameter defines minimum number of records in one data packet that can be sent to server
min_records: Min Saved Records
Home Network: On Move: Send Period
home_on_move_send_period
This parameter indicates frequency (time interval in seconds) of sending data to server
send_period: Send Period
Home Network: On Stop: Min Period
home_on_stop_min_period
Home Network: On Stop: Min Saved Records
home_on_stop_min_records
Home Network: On Stop: Send Period
home_on_stop_send_period
Digital Outputs
outputs2
out1: Output 1
out2: Output 2
Phone 1
phone1
Authorized phone number 1
number: Number
Phone 10
phone10
Authorized phone number 10
number: Number
Phone 2
phone2
Authorized phone number 2
number: Number
Phone 3
phone3
Authorized phone number 3
number: Number
Phone 4
phone4
Authorized phone number 4
number: Number
Phone 5
phone5
Authorized phone number 5
number: Number
Phone 6
phone6
Authorized phone number 6
number: Number
Phone 7
phone7
Authorized phone number 7
number: Number
Phone 8
phone8
Authorized phone number 8
number: Number
Phone 9
phone9
Authorized phone number 9
number: Number
Records
records
Enable records without time synchronization
Backend Server Host
server_host_1profile
Backend Server Port
server_port_1profile
Backend Server Protocol
server_protocol_1profile
protocol: Protocol
Server Response
server_response
Defines time period (in seconds) for server response to sent records
setdigout_2
sleep_mode_eol
Device sleep mode setup.
type: Sleep Mode
Sleep Timeout
sleep_timeout
Sleep timeout is time after which device goes to sleep or deep sleep if other requirements are met. It is measured in minutes.
SMS Data Sending
sms_data
Parameter allows or does not allow sending AVL data using binary SMS
SMS Number 1
sms_number1
SMS Event Number 1
number: Number
SMS Number 10
sms_number10
SMS Event Number 10
number: Number
SMS Number 2
sms_number2
SMS Event Number 2
number: Number
SMS Number 3
sms_number3
SMS Event Number 3
number: Number
SMS Number 4
sms_number4
SMS Event Number 4
number: Number
SMS Number 5
sms_number5
SMS Event Number 5
number: Number
SMS Number 6
sms_number6
SMS Event Number 6
number: Number
SMS Number 7
sms_number7
SMS Event Number 7
number: Number
SMS Number 8
sms_number8
SMS Event Number 8
number: Number
SMS Number 9
sms_number9
SMS Event Number 9
number: Number
Sorting
sorting
Records sorting order
order: Order
Static Navigation
static_nav
When static navigation is enabled, device filters out GPS jumps, when it is not moving
Stop Detection Source
stop_detection
Device can operate and change its working mode according to motion detection source: ignition (value 0), movement sensor (value 1), GPS (value 2)
source: Range
Unknown Network: On Move: Min Angle
unknown_on_move_min_angle
Unknown Network: On Move: Min Distance
unknown_on_move_min_distance
Unknown Network: On Move: Min Period
unknown_on_move_min_period
Unknown Network: On Move: Min Saved Records
unknown_on_move_min_records
Unknown Network: On Move: Send Period
unknown_on_move_send_period
Unknown Network: On Stop: Min Period
unknown_on_stop_min_period
Unknown Network: On Stop: Min Saved Records
unknown_on_stop_min_records
Unknown Network: On Stop: Send Period
unknown_on_stop_send_period
{"text":"getrecord"}
