Xirgo FM-500 Light+
Xirgo FM-500 Light+ is a device with GPS/GLONASS and GSM connectivity, designed for object tracking. It is able to acquire information on object location, speed, direction, etc. and transfer the data via GSM network. Digital and analog inputs of the device may be used to connect different external sensors/devices. Outputs of the device may be used to control external equipment remotely. Flexible configuration allows users/dealers to adjust the device to meet their specific requirements. It has 1-Wire (iButton), RS-232 and EIA-485 interfaces.
Parameters (114)
Settings (6)
Xirgo FM-500 Light+
Flespi parses telemetry data from your Xirgo FM-500 Light+ into a standardized JSON and lets you send commands to Xirgo FM-500 Light+ via API.
    "device.type.id": "Xirgo FM-500 Light+",
    "protocol.id": "bce"
How to send commands to Xirgo FM-500 Light+?
accident.event
Accident event detected
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
arm.status
Data Type 7
axle.weight
Axle weigth
Data Type 7
Data Type 7
CAN acceleration pedal level
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 12
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
can.j1587.dtc.fmi
can.j1587.dtc.lci
can.j1587.dtc.mid
can.j1587.dtc.oc
can.j1587.dtc.sid
can.j1587.dtc.status
can.j1587.dtc.type
can.j1939.dm1.dtc.awl
can.j1939.dm1.dtc.awl.flash
can.j1939.dm1.dtc.mil
can.j1939.dm1.dtc.mil.flash
can.j1939.dm1.dtc.pl
can.j1939.dm1.dtc.pl.flash
can.j1939.dm1.dtc.rsl
can.j1939.dm1.dtc.rsl.flash
can.j1939.dm1.dtc.sa
can.j1979.s10.dtc
can.j1979.s10.dtc.sa
can.j1979.s3.dtc
can.j1979.s3.dtc.sa
can.j1979.s7.dtc
can.j1979.s7.dtc.sa
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
engine.generator.status
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 6
event.function
Event function
Data Type 6
Data Type 7
filtered.ain
Filtered analog input value
Data Type 7
frequency.counter.din
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 9
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 6
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
tacho.engine.rpm
Engine RPM reported by tacho
Data Type 7
Data Type 7
Data Type 7
tilt.status
Data Type 7
Data Type 7
Data Type 7
total.trailer.weight
Total trailer weight
Data Type 7
ussd.data
USSD data
Data Type 11
Data Type 1,
Data Type 7
wiegand.code
Wiegand26 RFID code
Data Type 7
Fmset Force
fmset
Force Create Socket to Fmset
Activate output 1
type: Pulse Type
Activate output 2
type: Pulse Type
Output 3
output3
Activate output 3
type: Pulse Type
Signal 1
signal1
Static Signal 1
Signal 2
signal2
Static Signal 2
