Xirgo FM-500 Tacho
Xirgo FM-500 TACHO is a new generation fleet management device, equipped with a rich pack of interfaces (2 simultaneous CAN-bus interfaces, RS-232, RS-485, 1-Wire, Wiegand-26). The full range of CAN-bus data, remote tachograph data download, and a wide variety of available accessories make this device a powerful tool for satisfying the needs of the most demanding customer in the fleet management field.
Parameters (114)
Xirgo FM-500 Tacho
Flespi parses telemetry data from your Xirgo FM-500 Tacho into a standardized JSON and lets you send commands to Xirgo FM-500 Tacho via API.
    "device.type.id": "Xirgo FM-500 Tacho",
    "protocol.id": "bce"
How to send commands to Xirgo FM-500 Tacho?
accident.event
Accident event detected
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
arm.status
Data Type 7
axle.weight
Axle weigth
Data Type 7
Data Type 7
CAN acceleration pedal level
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 12
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
can.j1587.dtc.fmi
can.j1587.dtc.lci
can.j1587.dtc.mid
can.j1587.dtc.oc
can.j1587.dtc.sid
can.j1587.dtc.status
can.j1587.dtc.type
can.j1939.dm1.dtc.awl
can.j1939.dm1.dtc.awl.flash
can.j1939.dm1.dtc.mil
can.j1939.dm1.dtc.mil.flash
can.j1939.dm1.dtc.pl
can.j1939.dm1.dtc.pl.flash
can.j1939.dm1.dtc.rsl
can.j1939.dm1.dtc.rsl.flash
can.j1939.dm1.dtc.sa
can.j1979.s10.dtc
can.j1979.s10.dtc.sa
can.j1979.s3.dtc
can.j1979.s3.dtc.sa
can.j1979.s7.dtc
can.j1979.s7.dtc.sa
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
engine.generator.status
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 6
event.function
Event function
Data Type 6
Data Type 7
filtered.ain
Filtered analog input value
Data Type 7
frequency.counter.din
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 9
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 6
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
tacho.engine.rpm
Engine RPM reported by tacho
Data Type 7
Data Type 7
Data Type 7
tilt.status
Data Type 7
Data Type 7
Data Type 7
total.trailer.weight
Total trailer weight
Data Type 7
ussd.data
USSD data
Data Type 11
Data Type 1,
Data Type 7
wiegand.code
Wiegand26 RFID code
Data Type 7
Driver File Download
tacho_driver
DDD file download with all available driver information (inserted in slot1 or in slot2).
slot: Slot
Vehicle File Download
tacho_vehicle
Vehicle units (VU) file download. All information which tachograph contains for 90 days period. Can be downloaded with or without driver activity chart.
activity: Activity Chart
