Xirgo FMS500 Light+
Xirgo FMS500 Light+ is a GPS/GLONASS tracking device for fleet management supporting eco-driving, geofencing and overspeeding, fuel level sensors, driver identification, temperature/humidity sensors, RFID support, CAN-log connection, and a lot more.
Parameters (114)
Settings (6)
Xirgo FMS500 Light+
Flespi parses telemetry data from your Xirgo FMS500 Light+ into a standardized JSON and lets you send commands to Xirgo FMS500 Light+ via API.
    "device.type.id": "Xirgo FMS500 Light+",
    "protocol.id": "bce"
How to send commands to Xirgo FMS500 Light+?
accident.event
Accident event detected
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
arm.status
Data Type 7
axle.weight
Axle weigth
Data Type 7
Data Type 7
CAN acceleration pedal level
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 12
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
can.j1587.dtc.fmi
can.j1587.dtc.lci
can.j1587.dtc.mid
can.j1587.dtc.oc
can.j1587.dtc.sid
can.j1587.dtc.status
can.j1587.dtc.type
can.j1939.dm1.dtc.awl
can.j1939.dm1.dtc.awl.flash
can.j1939.dm1.dtc.mil
can.j1939.dm1.dtc.mil.flash
can.j1939.dm1.dtc.pl
can.j1939.dm1.dtc.pl.flash
can.j1939.dm1.dtc.rsl
can.j1939.dm1.dtc.rsl.flash
can.j1939.dm1.dtc.sa
can.j1979.s10.dtc
can.j1979.s10.dtc.sa
can.j1979.s3.dtc
can.j1979.s3.dtc.sa
can.j1979.s7.dtc
can.j1979.s7.dtc.sa
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
engine.generator.status
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 6
event.function
Event function
Data Type 6
Data Type 7
filtered.ain
Filtered analog input value
Data Type 7
frequency.counter.din
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 9
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 10,
Data Type 7
Data Type 1,
Data Type 7
Data Type 1,
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 10,
Data Type 7
Data Type 6
Data Type 7
Data Type 7
Data Type 7
Data Type 7
Data Type 7
tacho.engine.rpm
Engine RPM reported by tacho
Data Type 7
Data Type 7
Data Type 7
tilt.status
Data Type 7
Data Type 7
Data Type 7
total.trailer.weight
Total trailer weight
Data Type 7
ussd.data
USSD data
Data Type 11
Data Type 1,
Data Type 7
wiegand.code
Wiegand26 RFID code
Data Type 7
Fmset Force
fmset
Force Create Socket to Fmset
Activate output 1
type: Pulse Type
Activate output 2
type: Pulse Type
Output 3
output3
Activate output 3
type: Pulse Type
Signal 1
signal1
Static Signal 1
Signal 2
signal2
Static Signal 2
