Teltonika FM5300
Teltonika FM5300 is an advanced terminal with GLONASS/GPS positioning and GSM connectivity, which is able to get device coordinates and other data and transfer them via GSM network. This device is perfectly suitable for tracking remote objects (trucks, cars etc) quickly and easily. In case of lost connection Teltonika FM5300 can store more than 16000 records, and once the connection is re-established the device will send stored data via GPRS.
Parameters (731)
Settings (9)
Teltonika FM5300
Flespi parses telemetry data from your Teltonika FM5300 into a standardized JSON and lets you send commands to Teltonika FM5300 via API.
    "device.type.id": "Teltonika FM5300",
How to send commands to Teltonika FM5300?
AVL ID 9...10
s
AVL ID 713...716,
AVL ID 729...744
AVL ID 29
AVL ID 10820...10823
AVL ID 10808...10811
degree
AVL ID 10816...10819
degree
AVL ID 10832...10835
AVL ID 25...28
AVL ID 389
AVL ID 389
percantage
AVL ID 10445,
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
amps
amps
AVL ID 168
AVL ID 518
AVL ID 518
current
AVL ID 81
s
AVL ID 518
AVL ID 282
can.electric.engine.status
AVL ID 1035
AVL ID 235
celcius
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
s
Time to full from CAN bus
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
watts
amps
amps
AVL ID 388
AVL ID 518
CAN brake pedal pressed
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
AVL ID 518
amps
AVL ID 107
AVL ID 518
can.trip.engine.motorhours
AVL ID 102
amps
kW/h
kW/h
Webasto status read from CAN
custom.user.id
AVL ID 238,
AVL ID 4
AVL ID 842
AVL ID 88
AVL ID 10428...10431
AVL ID 641
Media type
AVL ID 20015
AVL ID 10611...10612
AVL ID 24
Tacho driver card presence
Tacho drive recognize
AVL ID 225
AVL ID 209
Profile 3: APN Name
gprs_apn
Profile 3: APN Password
gprs_apn_password
Profile 3: APN Username
gprs_apn_username
Profile 3: GPRS Content Activation
gprs_enable
enable: Enable GPRS
Digital Outputs
outputs
out1: Output 1
out2: Output 2
out3: Output 3
out4: Output 4
Profile 3: Backend Server Host
server_host
Profile 3: Backend Server Port
server_port
Profile 3: Backend Server Protocol
server_protocol
protocol: Protocol
setdigout_4
{"text":"getrecord"}
