Xirgo XG3700 TACHO SDK
Xirgo XG3700 TACHO SDK is a vehicle GNSS tracker with LTE support, 2 simultaneous CAN-bus connections, tacho readings, and MQTT-based data transfer protocol. The device features an accelerometer, internal odometer, 1-Wire interface, 3 digital inputs, 3 analog inputs, 2 digital outputs, optional waterproof (IP67) casing, and more. The functionality includes driver identification, geofencing, fuel level sensors (analog, frequency, and digital) support, temperature/humidity sensors support, overspeeding control, eco-driving, fuel flow meters support, remote output control and immobilization, remote temperature read from digital thermograph, upload of DD files to FTP, etc.
Parameters (144)
Flespi parses telemetry data from your Xirgo XG3700 TACHO SDK into a standardized JSON and lets you send commands to Xirgo XG3700 TACHO SDK via API.
    "device.type.id": "Xirgo XG3700 TACHO SDK",
    "protocol.id": "xirgo-mqtt"
How to send commands to Xirgo XG3700 TACHO SDK?
Sensor ID 0xA001
Sensor ID 0x3001,
Sensor ID 0x3002,
Sensor ID 0x3003
armed.status
Armed/disarmed status
Sensor ID 0x0060
Sensor ID 0x2041
Sensor ID 0x3004
Sensor ID 0x007F
can.activity.status
CAN activity status: if there were messages received last 10 seconds on CAN1 or on CAN2.
Sensor ID 0x009F
Sensor ID 0x2021
Sensor ID 0x0079
Sensor ID 0x302A
Sensor ID 0x302D...0x3031
Sensor ID 0x2040
Sensor ID 0x0078
can.bitrate
CAN bitrate
Sensor ID 0x4058,
Sensor ID 0x4059
can.check.engine.status
CAN check engine warning is on
Sensor ID 0x007A
can.command.id
Command Identifier, that is used by canbase_b function on CAN
Sensor ID 0x302B,
Sensor ID 0x302C
Sensor ID 0x0076
can.cruise.state
Cruise control state
Sensor ID 0x2031
Sensor ID 0x008F
Sensor ID 0x0085
Sensor ID 0xC015
Sensor ID 0x0084
Sensor ID 0x2008
Sensor ID 0x3021
Sensor ID 0x200A,
Sensor ID 0x2013
Sensor ID 0x4002
Sensor ID 0x203F
Sensor ID 0x300C
can.engine.torque.load
Engine torque load percentage read from CAN
Sensor ID 0x203A
Sensor ID 0x0081
Sensor ID 0x0062
Sensor ID 0x0063
Sensor ID 0x4001
Sensor ID 0x405A
Sensor ID 0xA01B
Sensor ID 0x3034
Sensor ID 0x0080
Sensor ID 0x2019
Sensor ID 0x203C
Sensor ID 0x3039
Sensor ID 0x008B
Sensor ID 0x0089
Sensor ID 0x0066
Sensor ID 0x008A
Sensor ID 0x201A,
Sensor ID 0x203E
can.j1979.engine.coolant.temperature
CAN J1979 engine coolant temperature
Sensor ID 0x2014
can.j1979.engine.fuel.rate
CAN J1979 Engine fuel rate
Sensor ID 0x303D
can.j1979.engine.rpm
CAN J1979 Engine RPM
Sensor ID 0x303B
Sensor ID 0x2016,
Sensor ID 0x2018
can.master.warning.light.status
Status of master warning light, read from CAN
Sensor ID 0x007E
can.messages.missed
Counter of missed messages from CAN bus
Sensor ID 0x4057
can.messages.received
Counter of received messages from CAN bus
Sensor ID 0x4056
Sensor ID 0x0086
CAN brake pedal pressed
Sensor ID 0x008C
Sensor ID 0x009D
Sensor ID 0x009E
Sensor ID 0x0064
Sensor ID 0x0065
can.retarder.selection
Sensor ID 0x2039
Sensor ID 0x2038
can.retarder.torque.mode
Sensor ID 0x2037
Sensor ID 0x3038
Sensor ID 0x2015,
Sensor ID 0x2017
Sensor ID 0x2006
Sensor ID 0x007C
Sensor ID 0x0067
Sensor ID 0x4003
Sensor ID 0x4062
Webasto status read from CAN
Sensor ID 0x0093
Sensor ID 0x301D
cargo.temperature
Sensor ID 0x3033
Sensor ID 0x3040...0x3043
Sensor ID 0x0003,
Sensor ID 0x0010,
Sensor ID 0x0011,
Sensor ID 0x0012,
Sensor ID 0x0013,
Sensor ID 0x0014,
Sensor ID 0x0015
Sensor ID 0x0094,
Sensor ID 0x0095,
Sensor ID 0x0096,
Sensor ID 0x009A
Sensor ID 0xC016...0xC017
Sensor ID 0x006D
event.function
Event function
Sensor ID 0x3000
Sensor ID 0x2007,
Sensor ID 0x2009
Sensor ID 0x202C
Sensor ID 0x0006
Sensor ID 0x009B
gnss.signal.weak.status
GNSS signal weak
Sensor ID 0x0007
Sensor ID 0x000B
Sensor ID 0x300A
Sensor ID 0x0008
Sensor ID 0x3009
Sensor ID 0x3008
Sensor ID 0x2003
Sensor ID 0x000A
Sensor ID 0x2005
Sensor ID 0xC014
Sensor ID 0x0088
Sensor ID 0x5000
Sensor ID 0x001E
last.success.registration.timestamp
Timestamp of last successful data registration
Sensor ID 0x4060
locked.status
Locked/unlocked status
Sensor ID 0x0061
Sensor ID 0x0002
Sensor ID 0x5004...0x5007,
Sensor ID 0xA000,
Sensor ID 0xA017,
Sensor ID 0xA018,
Sensor ID 0xA019,
Sensor ID 0xA01A
Sensor ID 0xE000...0xEFFF
Sensor ID 0x7003,
Sensor ID 0xD000
Sensor ID 0x300B,
Sensor ID 0xD000
Sensor ID 0x2002,
Sensor ID 0xD000
Sensor ID 0xB001,
Sensor ID 0xD000
Sensor ID 0xB000,
Sensor ID 0xD000
Sensor ID 0x2001,
Sensor ID 0xD000
Sensor ID 0x2000,
Sensor ID 0xD000
script.name
Script name
Sensor ID 0xC004...0xC006
sensor.boolean.value
User-defined sensor boolean value
Sensor ID 0x001F...0x005F
sensor.float.value
User-defined sensor float value
Sensor ID 0xA003,
Sensor ID 0xA004,
Sensor ID 0xA005,
Sensor ID 0xA006,
Sensor ID 0xA007,
Sensor ID 0xA008,
Sensor ID 0xA009,
Sensor ID 0xA00A,
Sensor ID 0xA00B,
Sensor ID 0xA00C,
Sensor ID 0xA00D,
Sensor ID 0xA00E,
Sensor ID 0xA00F,
Sensor ID 0xA010,
Sensor ID 0xA011
sensor.frequency
Frequency sensor value
Sensor ID 0x3022...0x3025
sensor.int16.value
User-defined 2 bytes sensor signed value stored as int16, indexed parameter
Sensor ID 0x7004...0x700D
sensor.int32.value
User-defined 4 bytes sensor signed value stored as int32, indexed parameter
Sensor ID 0x8000...0x8009
sensor.int8.value
User-defined 1 byte sensor signed value stored as int8, indexed parameter
Sensor ID 0x6000...0x6009
sensor.static.signal
User defined Static Signal flag, indexed parameter
Sensor ID 0x001B...0x001C,
Sensor ID 0x00A0...0x00A2
sensor.string.value
User-defined sensor string value
Sensor ID 0xC000,
Sensor ID 0xC001,
Sensor ID 0xC002,
Sensor ID 0xC003
sensor.uint16.value
Sensor ID 0x300D...0x301C
sensor.uint32.value
Sensor ID 0x4005...0x4054
sensor.uint64.value
Sensor ID 0x5001
sensor.uint8.value
Sensor ID 0x200B...0x2012
tacho.file.manager.state
Tachograph File Manager State
Sensor ID 0x202F
tacho.slot.activity
Slot activity from tachograph
Sensor ID 0x202D,
Sensor ID 0x202E
tacho.slot.distance
Slot distance from tachograph
Sensor ID 0x405E...0x405F
tacho.slot.time
Slot time from tachograph
Sensor ID 0x405C...0x405D
Sensor ID 0x4066
Sensor ID 0x405B
Sensor ID 0xA002
Sensor ID 0xB002
Sensor ID 0x0069
wiegand.code
Wiegand26 RFID code
Sensor ID 0x4061
Sensor ID 0x7000
Sensor ID 0x7001
Sensor ID 0x7002
Driver File Download
tacho_driver
DDD file download with all available driver information (inserted in slot1 or in slot2).
ttl: Time to Live
slot: Slot
Vehicle File Download
tacho_vehicle
Vehicle units (VU) file download. All information which tachograph contains for 90 days period. Can be downloaded with or without driver activity chart.
ttl: Time to Live
activity: Activity Chart
SMS: Bootloader Version
{"text":"bestpassword V"}
Send script remote command
{"output":13,"payload":"616E792062696E617279207061796C6F6164"}
