- Essentials
- How assets work
- Analytics integration
- How to create an asset?
- Assets API
- MQTT Topics
- Troubleshooting
Essentials
Assets are virtual entities in flespi that represent physical objects or resources (like drivers, trailers, riders, or vehicles) that can be linked with different tracking devices over time.
Asset contains intervals - historical timeline of device associations, automatically maintained as non-overlapping time segments.
Assets can be assigned to calculators to enable asset-based interval detection and analysis.
Assets have a priority range from 0 to 100, with higher priority assets being checked first in case of intersections.
Assets can be organized into groups, similar to device grouping.
How assets work
Asset functionality is based on intervals registration which define when a device is linked to an asset. Each interval contains:
- begin - interval start time
- end - interval end time (0 means unlimited)
- device_id - device linked to the asset during this interval (0 means no devices linked with this interval)
- meta - custom data associated with this interval (up to 8 KiB of JSON)
- timestamp - interval registration timestamp
Intervals are automatically managed to maintain a continuous and non-overlapping timeline. When a new interval is registered, the system recalculates existing intervals to ensure consistency.
To effectively "delete" an interval, you create a new interval with device_id=0 that overlaps with the target interval. This creates a corresponding period in the timeline.
Asset intervals are subject to the intervals_ttl setting of the asset, which determines how long intervals are stored in the database.
Assets can be used standalone to maintain the historical timeline of device associations or together with devices and calculators to provide device/asset relationship context into analytical calculations. To provide such a context, assets should be assigned to the calculator either directly or through groups.
Assigned assets can be accessed in all calculator expressions using special functions:
- asset() - returns the asset with the highest priority to which the device was linked at the given time
- assets() - returns an array of all assets to which the device was linked at the given time
These functions enable:
- Interval splitting: Use asset/device intervals history to define interval boundaries in selectors
- Asset tracking: Identify which assets were linked to a device during specific time periods in counters
- Metadata access: Retrieve asset interval details including begin/end times, registration timestamp, and custom meta information
The asset() function accepts an optional parameter to specify which fields to return. For example: asset("name,id,interval") will return name id and asset interval properties such as device assignment begin, end time and its meta.
You can test if a device was assigned to any asset using: asset() != null. Or check if a device was not assigned to any asset with: isnull(asset()).
Calculator automatically triggers intervals recalculation for all assigned devices when its list of assigned assets changed, and also upon any asset interval update for the corresponding time period. Both happen only when the calculator has "update_onchange" option enabled.
- Log in to the flespi panel
- Navigate to Telematics hub -> Assets and click the "+" button
- Give the asset a name and click Save.
- Go to the Calculators or Groups tab for the asset and assign it to the entities you want to link it with.
How to assign an asset to a device?
Go to the Asset Intervals tab to assign an asset to a device.
Here, you may select an area on the Gantt timeline chart to assign the device. Also, you may click on the interval to edit.
You can switch the timeline display mode between Gantt and a flat timeline.
You can also zoom the area. To do this, select the appropriate selection mode and highlight the area.
To navigate the timeline – you can use scrolling or select a date in the date picker.
Assets API
To perform any operations with the assets, use the assets API.
MQTT topics
You can monitor asset intervals via MQTT topics:
- flespi/interval/gw/assets/{asset_id}/created - asset interval was created
- flespi/interval/gw/assets/{asset_id}/updated - asset interval was updated
- flespi/interval/gw/assets/{asset_id}/deleted - asset interval was deleted
- flespi/state/gw/assets/{asset_id}/last - contains interval with the latest begin/end timestamps
- flespi/state/gw/assets/{asset_id}/active - contains currently active interval, if any
Messages posted in asset MQTT topics contain a 'trace' user property which you can use to link actual interval modification events with REST API calls.
Troubleshooting
In case of any issues, check the Logs tab. There you will find all modifications that were done to an asset within the last 365 days including any interval event.
