6 August, 2026
Every device starts long before it connects
When hardware manufacturers and platform engineers build products together
There’s a moment every hardware manufacturer knows well. A new tracker is almost ready. The hardware has passed testing. Firmware is stabilizing. The launch date is approaching. One question remains. Will customers be able to connect it on day one?
For many manufacturers, that's when the first message arrives. Not after the release. Long before it.
What follows is rarely just another protocol implementation. More often, it's weeks – sometimes months – of collaboration between firmware engineers, product managers, QA specialists, and protocol developers. Draft documentation changes, firmware evolves, new parameters appear, packet captures replace assumptions, and dozens of small engineering decisions gradually turn a specification into a production-ready integration.
Although every manufacturer has its own workflow, these collaborations tend to follow the same patterns. Over the years, we've seen them repeated hundreds of times, regardless of the device, protocol, or company behind it.
Preparing for a launch
One of the most common conversations starts before the product itself exists publicly.
Sometimes we receive an early protocol specification together with a firmware build. Sometimes it's an engineering sample that hasn't left the lab yet. Occasionally, the request arrives only days before a trade show, with one simple goal: make sure customers can start using the new hardware immediately after the announcement.
That early collaboration gives both engineering teams time to validate the implementation while changes are still easy to make. Instead of waiting for customer feedback after launch, protocol behavior can be verified in advance, edge cases can be discussed, and new functionality can be supported before the first production devices ever reach the field.
Whether the project involves a compact asset tracker, an AI dashcam, or an industrial gateway, the objective is always the same – shorten the time between product launch and real-world deployment.
Firmware never stops evolving
Launching a device is only the beginning. Firmware continues to evolve throughout the product's lifetime, and protocols evolve with it. New telemetry appears, packet structures change, diagnostic messages become more detailed, and entirely new capabilities are added long after the hardware reaches customers.
Keeping pace with those changes isn't just about writing more parser code. Much of the work involves understanding exactly what changed between firmware versions, validating new behavior, and making sure existing integrations continue to work as expected.
Sometimes the update introduces dozens of new parameters. Sometimes a feature behaves differently from an earlier firmware revision. And occasionally, the implementation reveals details that simply weren't visible in the original documentation. Every revision becomes another collaborative engineering cycle rather than another software release.
An independent view of the protocol
One of the most valuable roles flespi plays during development is acting as an independent implementation of the protocol.
As new firmware is being tested, manufacturers often compare device behavior against flespi to validate protocol changes, confirm new functionality, or better understand differences between expected and actual traffic. Having two independent implementations looking at the same packets makes subtle inconsistencies much easier to spot than relying on a single environment.
Sometimes the difference comes from firmware. Sometimes from documentation. Sometimes it's simply two perfectly reasonable interpretations of the same specification. In every case, the goal is the same – understand how the device behaves in practice before customers encounter those differences themselves.
Engineering happens in one place
These conversations rarely happen through isolated emails. Most of them take place in Helpbox, where engineers from both companies work in a shared technical workspace. Protocol specifications, firmware builds, packet captures, parser drafts, implementation notes, Wireshark traces, and test results all become part of the same ongoing discussion. That continuity matters.
A conversation that starts with a protocol revision today often continues months later with a firmware update, a new hardware generation, or an entirely different product based on the same protocol. Instead of rebuilding context every time, both teams build on everything they've already learned.
Over the years, many of these workspaces have grown into a shared engineering history spanning multiple product generations.
AI handles the routine; engineers solve problems
The biggest change in recent years hasn't been the collaboration itself. It's how much faster that collaboration can move.
Today, AI helps compare protocol revisions, extract packet structures from documentation, identify changes between firmware versions, prepare parser drafts, and highlight inconsistencies long before an engineer begins implementing support. Tasks that once required hours of manual comparison can now be completed in minutes.
What AI doesn't replace is engineering judgment.
Engineers still decide how a protocol should behave, investigate edge cases, validate real traffic, and work directly with manufacturers to make sure new hardware performs as expected. AI simply removes much of the repetitive work, leaving more time for the conversations that actually move projects forward.
Conclusion
Every collaboration is different. Some begin months before a product launch. Others continue for years as devices, firmware, and protocols evolve together. Some focus on compliance, others on video telematics, diagnostics, or entirely new communication protocols.
What they all have in common is that protocol support has become only one part of a much broader engineering partnership.
Behind every one of the more than 1.4k supported device types on flespi is a shared effort between engineers working toward the same goal: making sure that when a customer powers on a new device for the very first time, everything simply works.
